Micael
posted on 14/10/04 at 03:34 PM |
Steering coupling
Hi!
Does anyond know where I can get this coupling (see attached file)? I have one almost identical but it dosen't have the bolt and splines on the
lower end. Also where can I get an lower steering colum with suitible splines in each end? The swedish SVA (SFRO) don't like welded steering
colums, so I need one in one piece.
![](/galpreviews/a147390-DSC00253.jpg) ![Rescued attachment DSC00253.jpg](/gallery/a147390-DSC00253.jpg) Rescued attachment DSC00253.jpg
Micael Moose Åman
Petrolhead and all around nice guy
"Don't leave the duck there. It's totally irresponsible. Put it on the swing, it'll have much more fun." //Sleep Talkin Man Dec 23
2009
Mark Allanson
posted on 14/10/04 at 05:24 PM |
I've never seen anything like it, although it does look like it is designed to fit a Ford steering column with the triangular input. May be
worth a trip to the scrapyard and look at some Granada's?
James
posted on 14/10/04 at 06:04 PM |
I have a feeling (though I may be imagining it) that it's the bottom part from a power steering column on either a DOHC or a CVH.
It looks distinctly similar to the Sierras I was poking around in the scrappy recently. They were all either DOHC or CVH and had power steering.
Hope that helps,
James
[Edited on 14/10/04 by James]
Micael
posted on 14/10/04 at 06:16 PM |
It might be worth a visit to the scrappy then
Micael Moose Åman
2009
Hasse
posted on 15/10/04 at 05:56 AM |
Hello Micael,
Dont know from which car the coupling comes, but it should not be a problem to pass SFRO with a well executed welding job on the steering shaft. I
know at least 5 cars with welded shafts. All passed.
/Hasse
theconrodkid
posted on 15/10/04 at 06:22 AM |
most factoty produced shafts are just friction welded i drilled and pinned mine prior to welding,used a brake pad retaining pin from a vauxhall
who cares who wins
pass the pork pies
Micael
posted on 15/10/04 at 07:52 AM |
quote: Originally posted by Hasse
Hello Micael,
/Hasse
I know and that is the problem.
Diffrent SFRO guys has diffrent opinion about this. The one I spoked to didn't like welded colums.
It's the same with poly bushes in the traling arms. Some SFRO guys accept it and some don't.
However, the space around the lower coupling is so limited that I can't weld a tube around the colum. The only weld i can do is what we call in
Sweden a "stumsvets". Basically this means that you weld orginal colum end to end to the new colum.
The best thing to do would be to build a homgenous colum with splines in each end and use the coupling on the picture.
[Edited on 15/10/04 by Micael]
Micael Moose Åman
2009
Rob Lane
posted on 15/10/04 at 08:42 AM |
That looks like a steering coupling from a Transit van. The 90's Transits had 3 I think in the steering lineup.
I well remember looking at the down link from column through bulkhead and thinking it was a nice joint with an acute angle of operation.
(Just re-read that, it sounds suggestive somehow)
