mcerd1
posted on 23/7/13 at 06:16 PM |
OT - Vinal floors and washing machines ?
my random question for the day - is there an easy way of getting a washing machine under a counter and back out without catching on the flooring ?
loggyboy
posted on 23/7/13 at 06:23 PM |
How far under does the vinyl go?
Mistral Motorsport
posted on 23/7/13 at 06:24 PM |
Couple of strips of wood to slide it in on, then pull the wood out.
posted on 23/7/13 at 06:39 PM |
Has it not got two wheels front or back?
Bit of thin plywood would do it.
mcerd1
posted on 23/7/13 at 07:08 PM |
sorry should have said: the vinyl goes all the way back, there are no wheels and I've got almost zero height to play with
I was wondering if a thin sheet of steel / alloy would work ?
Hurdsey
Rub a bit of washing up liqued on the floor in line with the feet and away you go.
Chris_vrs
posted on 23/7/13 at 07:23 PM |
Wind the adjustable feet in and lower it enabling you to lift it and pull out? That's if they are adjustable like mine?
www.gardencitylocksmiths.co.uk
mark chandler
posted on 23/7/13 at 07:27 PM |
Even if you get it in the feet will dig holes when it's been run, I feel your pain after moving mine about last weekend
No substitute for tiles
adam1985
posted on 23/7/13 at 07:38 PM |
Tip from a floor layer a know spray furniture polish on floor before you put it in. Tryed it and it works
posted on 23/7/13 at 08:47 PM |
I wouldn't risk it, stick some ply under it, lined up so the back legs drop off it in the right place. Vinyl is terrible for tearing.
dickie b
posted on 23/7/13 at 09:50 PM |
I had exactly same problem - my solution was to slide under the feet very thin bendy plastic dining place mats.
Unit the slid out gently and feet couldn't dig in.
Worked a treat - but just make sure the mats remain under the feet as you haul it out!
owelly
posted on 23/7/13 at 10:10 PM |
Slide it in on ice cubes then let them melt.
http://www.ppcmag.co.uk
Grimsdale
posted on 24/7/13 at 07:29 AM |
i did this with sheets of card when i did this last year
mcerd1
posted on 24/7/13 at 12:04 PM |
well it seems I'm not alone then... cheers guys
how does this sound - I'm thinking about getting a thin sheet of stainless (say 0.5mm to 1.2mm max) and cutting 2 long strips about 2" or
3" wide, then screwing these strips to the floor down the sides (in line with the feet)
do you think this would work or would the machine move around too much when its running ?
bartonp
posted on 24/7/13 at 12:20 PM |
I had some vinyl left from fitting the floor. Cut a piece the same size as the WM, put it underneath UPSIDE DOWN with a coating of furniture polish
inbetween. Slid in/out lovely....
Vindi_andy
posted on 24/7/13 at 01:36 PM |
When I fixed then for a living I used to hate vinyl floors usually because people stopped at the front of the opening.
Agree with a previous post re washing up liquid but i would suggest roccking the machine side to side and front to back before attempting to move it
to break the seal that develops over time.
I then bought a piece of thick polythene that was longer than the standard worktop is deep, that I kept rolled up in the van for just this purpose. I
would slide it under the front legs as far back as I could then use the washing up liquid trick under the front legs while lifting the back ones to
get all 4 on the sheet then slide the whole thing out on the polythene.
Tore a couple of floors early on befor ei Learnt these tricks.
mcerd1
posted on 24/7/13 at 02:04 PM |
well that shouldn't be an issue this time at least, I'm getting all new flooring to add to the all new appliances...
(this house is costing me a flipping fortune just now - it put a second car sized dent in my kitcar budget )
[Edited on 24/7/2013 by mcerd1]
Vindi_andy
posted on 24/7/13 at 02:21 PM |
I have learnt from personal experience so whenever I fit a floor I always "flood" the flooring into the opening.
The latest hate in terms of flooring is laminate because people (my dad) dont move the appliance and then floor up to it and then ask you to repair
their machine as a favour and you cant get the flippin thing out cos the floor is 8mm higher then the floor in the opening
jossey
posted on 24/7/13 at 04:16 PM |
Yup same as we do some water n washing up liquid under it.
To get it out squirt some under the washer then mop up when you get it out...
We are talking washing machines still ye?
David Johnson
jossey
posted on 24/7/13 at 04:24 PM |
Mcerd1 this is my dent left in my Kitcar budget...
£28,000 insurance claim cost me about £1000 in excess n food etc living in a hotel for 9 weeks.
It happened 2 weeks after we finished the renovation too....
David Johnson
jacko
posted on 24/7/13 at 04:51 PM |
never tried it but how about sitting it on cups like you put under bed wheels
mcerd1
posted on 25/7/13 at 07:44 AM |
ouch
it happened to one of the GF's friends last year too - it was a ground floor flat that they'd just spent ~£20k sorting.
a flat 4 floors above them had re-plumbed and connected to the wrong drains (old edinburgh tenements with lots of redundant pipes)
they said the claim was for over £56k in the end and they ended up renting another flat as it took 6 months to sort
Vindi_andy
posted on 25/7/13 at 11:04 AM |
Unfortunatley the cups dont work as they are still 4 single points. Personally the best is a thin sheet of polythene and if, unlike me, you are only
moving the one, leave it under the machine when youve slid it back in.
jossey
posted on 25/7/13 at 06:47 PM |
ouch
Wowwww 56k
David Johnson
