Author: Subject: MNR Vortx RT PLUS Inboard Raceleda Spec
Krismc
posted on 28/7/13 at 07:39 AM Reply With Quote
MNR Vortx RT PLUS Inboard Raceleda Spec. IVA registered March 2011 with new registration plate.
Right Chaps after 1 year building and 2 years driving im selling up as I want another project.
here are the pictures......
Front End & Steering
- Raceleda Alloy Hubs
- Raceleda Alloy Uprights
- Raceleda Alloy 4 Pot Front Callipers
- Raceleda Groved
- Inboard mounted Protech fully adjustable coil overs/damper unit, Push rod activated
- Rally design Quick rack.
- MNR/Ford modified collapsible column
- Twin circuit brakes with Willwood master cylinders,
- Brake pedal adjuster (locked for IVA).
- Willwood hydraulic clutch master cylinder
- Fully Rosejointed suspension
All Raceleda parts are based on 'Cortina geometry' and made of a light weight Alloy.
Rear End & Drive
- Ford Bolt on driveshafts
- Ford 3.62 diff
- Type 9 gearbox
- Burton Lightened Flywheel and ring gear
- Burton hydraulic Clutch kit
- New Sierra spec rear disc kit with budweg callipers
Engine
- 2000cc Zetec Black top Engine
- Raceline Water rail
- Relocated Alternator bracket for easy adjustment and to prevent heat soak
- Dunnell Shortened Sump
- Dunnel Modified Oil Pick up
- Modified R1 fuel injection system
- Modified R1 throttle boddies
- MNR Inlet manifold
- External Pipercross filter
- MBE ECU.
- AAS Stainless Repackable exhaust system with integral race spec Cat
- Stainless Water hoses connected with blue raceline silicon hoses
Interior
- Customised Black and Orange trimmed Cobra 7 Seats
- Willians Easy adjust 4 point harnesses
- Interior side panels are carbon-look
- Carbon Tunnel cover inlay
- Carbon dash inlay (a beautifully made seemless carbon inlay).
- Custom ETB Black with orange clocks for Water Temp/Oil Pressure/Oil Temp/Battery/Tacho/Speedo/millage/Fuel.
- Round 16 & 18 gauge tubular chassis
- Black Powder coated chassis
- Increase triangulation including side bars
- Roll over hoop formed into chassis and made of T45.
Exterior
- Orange GRP body
- MNR Orange 'Original style' nose cone
- Custom Orange GRP bonnet scoop
- R1 Bike Mirrors
- 15 inch Ford pattern alloys
- Toyo R1 Tyres
Summary
The car has been built from nearly all new parts unlike most kit cars, it can be a very fast road car and would also be a trackday car if required due to the very extensive design and the amount of adjustment in all suspension arms, It is very easy to drive distance in than most due too being fitted with the most reliable engine available the 2000 Zetec and a Type 9 box Also ive fitted Soft but firm Holding cobra Bolstered seats, Full race spec suspension which is fully adjustable in height and damper rebound which is also great on the road and takes pot holes with ease, the rally design quick rack has been fitted so your hands dont have to cross as much and gives more feel to the steering. Reliable Fuel injection with expensive MBE ECU meaning the car starts first time, every time!! Low Low Weight and high power output which gives it a High Power to weight ratio.
There are a couple of body scratches (very minor) and Wheels and Tyres are in a excellent condition along with all the pads and discs.
Can supply all build photos, Was took to MNR where they checked build of car, completed paper work and Completed IVA with VOSA and then DVLA Issued a 2011 Plate due too amount of new parts used, after 500 Miles Brakes where stripped and Checked and the Suspension was laser tracked and setup. And then due to work commitments ive only completed a Further 2000 Miles.
Digital Mileage Clock Reads 2560 Miles, Bills in excess of £27K (yes thats no a typo), The car is finished to a high standard with reliability considered throughout the build.
Sad too see it go but Priced to sell at just.
£11995 Im open to offers, swaps, trade downs and trade ups.
07929167193
kris.mcgough@sky.com
[Edited on 28/7/13 by Krismc]
big_l
posted on 28/7/13 at 07:45 AM Reply With Quote
Nice car I've seen this in the flesh I'm sure you'll sell it easy at that price..
Check out my blog mnrvortxhayabusa@blogspot.com
Krismc
posted on 28/7/13 at 07:51 AM Reply With Quote
Thanks Matey.
I was told £13500 is what people normally post them as and to accept a offer at about £12995. So I thought with most people not having much money lying around Id cut straight to the chase and ask what people can afford.
Oh and I can arrange delivery for people and ill go halfs up to a certain amount.
Kris
Krismc
posted on 30/7/13 at 03:57 PM Reply With Quote
Easy achievable to 205Bhp which it previously had before i removed the cams.
typo... mileage reads 1560
[Edited on 30/7/13 by Krismc]
Krismc
posted on 3/8/13 at 08:05 PM Reply With Quote
For the people who asked for pictures of the seats.
Also I havent got a current picture of the hubs unless i take a wheel of but here is a pic from build.
[/URL]
[Edited on 4/8/13 by Krismc]
Krismc
posted on 4/8/13 at 05:43 PM Reply With Quote
BTTT Pictures added
Krismc
posted on 10/8/13 at 07:38 AM Reply With Quote
BTTT.
I dont mind interested people taking a look, or giving someone a ride out but Please have the means to buy my car if you test drive it and waste 4hrs of my friday night when I cancelled going out drinking!
....he ended up saying he only had £5k and was hoping he could persuade me to reduce it. im not angry cause he was a idiot.
Wheels244
posted on 10/8/13 at 08:48 AM Reply With Quote
£5k !!! What a Dick !!
I had all sorts of crap offered in part ex for mine.
Someone offered me a straight swap for a Renault Clio - I didn't have to think too long about that one.
posted on 10/8/13 at 09:13 AM Reply With Quote
I have recently had the good fortune to acquire some magic beans, if you were to be in need of an adventure the likes of which you have never before undertaken I would be willing to swap them for your car (plus a cow if you have one)
Krismc
posted on 10/8/13 at 08:31 PM Reply With Quote
As long as each bean is worth £1 each and you have at least 11k of them plus a horse and ill give you my Car and my COW
Krismc
posted on 11/8/13 at 04:31 PM Reply With Quote
BTTT
Krismc
posted on 12/8/13 at 07:03 PM Reply With Quote
BTTT
PNichols
posted on 13/8/13 at 07:07 AM Reply With Quote
Lovely looking car/spec, I'd be interested if it was nearer my budget
Krismc
posted on 13/8/13 at 01:04 PM Reply With Quote
Stretch ya budget! Its priced to sell and theres nothing this new with that spec for sale else where, ive checked!
Dont make me trade it in people.
Kris
PNichols
posted on 13/8/13 at 01:58 PM Reply With Quote
Ha, lower the price !lol
Cant really go into the teens tbh, just bought an M3 CS and funds have taken a hit, but lovely car.
Krismc
posted on 13/8/13 at 04:51 PM Reply With Quote
...I dont feel sorry for u if your other cars a M3. Make a sensible offer and ill deliver it too ya door!
PNichols
posted on 13/8/13 at 05:27 PM Reply With Quote
Ha should of said a grab ant or something lol
Depends on sensible mate, wouldn't want to offend you or harm your chance of getting closer to your asking price, if you have a least price figure, send me a pm/u2u thingy.
Krismc
posted on 13/8/13 at 06:19 PM Reply With Quote
...really im at my least price! But I hey why not. u2u sent.
Krismc
posted on 18/8/13 at 09:14 AM Reply With Quote
Now reduced on Ebay
http://www.ebay.co.uk/itm/231035135058?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Krismc
posted on 22/8/13 at 07:38 PM Reply With Quote
BTTT
Krismc
posted on 5/9/13 at 05:20 AM Reply With Quote
Sold but not collected as guy was erm too erm shall we say wide for seats.
so still for sale.
Krismc
posted on 6/9/13 at 07:18 PM Reply With Quote
Now for sale in a garage near you so you can get finance!
[Edited on 6/9/13 by Krismc]
Krismc
posted on 11/9/13 at 05:16 PM Reply With Quote
BTTT, Price show in the picture isnt the price you will pay!
Krismc
posted on 18/9/13 at 08:20 PM Reply With Quote
BTTT
