LoMoss
| posted on 8/8/13 at 06:26 PM |
Xflow ignition problem
Hi All
Have an luminition ignignition system fitted which is now not producing a spark. Would like to convert it back original or to another electronic
ignition. Any recommendations or parts would be appreciated.
Hall
| posted on 8/8/13 at 06:27 PM |
Trigger wheel, edis and coil pack. Sorted.
ianclark1275
| posted on 8/8/13 at 08:48 PM |
try "powerspark" module
ebay
seller is simonbbc
ive took out a magnetronic and fitted on in a lucas 45 for a mini and it was fine.
just need to adjust timing slightly as magnets are in a slightly different orientation.
need to make sure coil is correct, that usually causes the modules to fail...
standard is generally best
test with mulitmeter for ohms.
IC
measure twice, cut once, scrap it, start again.
ianclark1275
£24.99
theduck
| posted on 8/8/13 at 09:47 PM |
Accuspark. Also do an add on programmeable ignition unit.
black fingernail
| posted on 9/8/13 at 06:36 PM |
I think you can just remove the 'magic eye' and the four bladed 'chopper' wheel and just fit a set of points and a condenser,
until you decide which replacement electronic system to use, or get your system tested by someone who knows, and repaired.
make sure you have a ballast resistor type coil fitted, and of course a ballast resistor low tension lead. or your points will burn very quickly.
LoMoss
| posted on 3/9/13 at 03:28 PM |
Update
Fitted accuspark dizzy and electronic points £64.00 delivered. Works a treat.
Moss
steve m
| posted on 3/9/13 at 06:15 PM |
That's what's on mine as well,
its good stuff
steve
