R13 Alloys, Dyna Ignition Module+ Coil pack.
Hi guys, clearing out some items from the garage, being over cluttered with stuff i no longer need.
First I have a set of 6x13 Split Rim Image Alloys, In good condition (some marks brake dust), with matador slicks on two , matador wets on the other
two.
The wets have a good amount of tread remaining. These are medium-hard compound, suitable for track days. Would advise against sprints and climbs, as
they are not soft enough.
These are extremely light alloy wheels, must be no more than ~5kg . You can tell when you lift them up, as you pick them up so fast expecting them to
be heavier. Certainly lightest alloys I've ever used.
108 PCD, ford centres. Came off a Radical Clubsport.
Edit- Offset, 29.0 marked inside, I like to measure stuff myself however, and made it to be +27.5mm. ~27.5-30mm.
All tyres are 185/53/R13
2nd Item for sale is a Dyna 2000 Digital Ignition Control Module and Coil pack.
These were removed from the car along with it's previous engine (Zx 10R). Other than abit of grease on the surface they should be in 100%
working order. I think there is still a part that needs removing from the old Zx 10R engine.
These retail at $399. ~£250.
Dyna 2000 Item Discription <-- Click Me.
Looking for £300 for wheels. £150 for The Ignition Module and Coil Pack.
Open to sensible offers of course. U2U me for any queries.
I am based near Lichfield, just off the A38 , 30 Mins North of Birmingham.
Cheers. Scott.
[Edited on 12/8/13 by bennettimp]
