Author: Subject: Marine ply or other sheet material?
ReMan
posted on 23/8/13 at 09:37 PM Reply With Quote
giits
giits
As per pic my drive gate have survived with the plywood shhet for security/non-visibility
However after about 13 years (was there when we moved in) the wood has failed.
With nothing other than a varnish, which i've never re-done I assume that this would bneed to be marime ply to replace it with?
Ot is ther anopther material, ply or otherwise that would look cosmetically good and last for at least 5 years at a reasonable price?
Please dont say asbestos
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
watsonpj
posted on 23/8/13 at 10:29 PM Reply With Quote
its a car forum so someones got to say Carbon fibre and if you want to do it cheap Carbon fibre wrap on fibreglass
Charlie_Zetec
posted on 23/8/13 at 10:31 PM Reply With Quote
I think Wickes stock an acrylic or GRP laminate sheet that can be used for skylights? I know that you can buy transparent (or near to, which doesn't solve your privacy issue), but I believe they also do opal/opaque which might suffice. It's lightweight, but won't take as much of a beating as marine ply if you bash into it....
Charlie_Zetec
posted on 23/8/13 at 10:32 PM Reply With Quote
That was option B!
ReMan
posted on 23/8/13 at 10:37 PM Reply With Quote
Sorry, its a CF free zone like my car
Much as I'd like it chequer plate ally is Also out due to blending in with the area in general and trying not to drag it down more than usual
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
posted on 23/8/13 at 10:38 PM Reply With Quote
Marine or exterior grade ply, oiled for protection. A capping strip of timber on top would finish it of and help keep water out as well.
ReMan
posted on 23/8/13 at 10:40 PM Reply With Quote
I dont know much about it, so is exterior grade a possibility?
I like the thinking of either a cap or an upside dpwn U section plastic or metal to protect the top edge
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
renetom
posted on 24/8/13 at 07:46 AM Reply With Quote
Black plastic floor protection sheets
weather proof , very cheap, light, cant see through it.
last time i bought some were about £4 each 8'x4'.
corrado vr6
posted on 24/8/13 at 07:52 AM Reply With Quote
Above is called
Buffalo board or Corex
HTH
http://r1indy7.wordpress.com/
jon200
posted on 24/8/13 at 07:53 AM Reply With Quote
Can't you just use feather edge that's used for fencing?
Irony
posted on 24/8/13 at 07:58 AM Reply With Quote
You could use correx. Which is a fluted plastic. I'd use diabond. Its a aluminium nylon composite. Buy it from a company called Trent plastics. They deliver cut to size.
Smoking Frog
posted on 24/8/13 at 08:18 AM Reply With Quote
Fix a narrow platter to the bottom of each gate and grow ivy, clematis or honeysuckle. Or just zip tie some thick plastic, tarp or ground sheet.
Volvorsport
posted on 24/8/13 at 09:13 AM Reply With Quote
WISA 2/3
or brazillian ply
or any other method...
www.dbsmotorsport.co.uk
getting dirty under a bus
