Author: Subject: Bike Carbs. CVK V421 for xflow????
LoMoss
posted on 3/9/13 at 01:32 PM Reply With Quote
Hi
I have aquired a set of Keihin CVK V421 CF07 bike carbs.
Would these make a good conversion for a 1600 xflow? Googling does not provide much info.
If they would I will a have a set of twin 40s up for grabs.
Hall
[Edited on 3/9/13 by LoMoss]
whitestu
posted on 3/9/13 at 02:46 PM Reply With Quote
What size are they?
LoMoss
posted on 3/9/13 at 03:30 PM Reply With Quote
36mm dia.
Think they are off a 1000cc bike.
whitestu
posted on 3/9/13 at 03:33 PM Reply With Quote
That sounds about right - Mine are 38mm on a 2.0 Zetec and work really well.
LoMoss
posted on 4/9/13 at 08:42 AM Reply With Quote
Any advice for fitting, jetting & filters etc
Moss
whitestu
posted on 4/9/13 at 09:21 AM Reply With Quote
There are a couple of options for fitting - the easiest is leave them spaced as they are and get a manifold made from someone like Fastdan on here or Bogg brothers.
Alternatively you tou make your own manifold or respace the carbs and use bike carb rubbers to bolt to a manifold plate like I did, depending on what bits you can get to fit those carbs. Knowiung which bike they were off would help.
For the filter a px600 type backplate and filter will work fine.
For jets it is a matter of trial and error and also a question of getting the needle height right. Either way you will ultimately need at least wideband AFR meter and ideally a rolling road session to get the mixture set up properly.
Doa search on setting up bike carbs and you should find some good info on how they work.
Stu
LoMoss
posted on 4/9/13 at 09:28 AM Reply With Quote
Hi stu
Thanks.
Been doing a bit of googling & reading up. My head hurts!
Moss
whitestu
posted on 4/9/13 at 09:40 AM Reply With Quote
With the jets, they can be drilled out so worth getting a few fine drill bits. Mine ended up as 1.6mm.
Stu
mcerd1
posted on 4/9/13 at 09:53 AM Reply With Quote
sounds like the carb's are the right size, but it might help you get spares etc. if you can find out which bike they came from
this site might help you:
http://www.gadgetjq.com/keihin_carb.htm
send us a u2u with your e-mail address - I've got a nice step by step guide for you
[Edited on 4/9/2013 by mcerd1]
