davev8app
posted on 10/9/13 at 08:43 AM |
Triumph spitfire brakes how good?
Hi i am rebuilding / modifying a dutton s2 which has spitfire front brakes and was wondering how much horse power they will stop for a track day
car?
Also what upgraded options are available to me ?
id like to keep the uprights as they look nice and light
i am on a very low budget but have lathe and milling machines etc available to me
thanks dave
mark chandler
posted on 10/9/13 at 09:16 AM |
Spitfire, herald uprights were very popular in their day, better geometry than cortina in fact just not as strong in a crash and availability dried
up. Lots of pre IVA cobra,s used these.
If building a light car expect them to be fine, just use EBC green stuff pads or similar, if you are running a ford back axle then consider the
different PCD's for the wheels.
Regards Mark
posted on 10/9/13 at 11:05 AM |
Truimph "Alford & Alder" uprights with bolt on caliper brackets and steering arms are good and every easy to upgrade but
early in production to reduce production costs a major change was made to Spitfire and Herald uprights and the calliper bracket and steering are
part of the main casting. However the Vitesse and GT6 retained the separate mounting brackets and steering arm and also use a fatter stub axle.
To upgrade from the basic it is really just a case of fitting Vitesse/G6 uprights which on most versions come complete with bigger discs and
either P16 or M16 callipers. As this type of upright was used in numerous single seater Formula there are also a large number of upgrade
parts available.
Apparently this upright and associated parts are still manufactured by a small engineering out fit in Coventry who supply a version to Caterham
and the classic single seater racing fraternity
davev8app
posted on 11/9/13 at 07:19 AM |
Thats useful info that the GT6 has bolt on brackets ..just checked mine they are the are the later fixed type ..i am hopping the spit brakes will be
ok with 145hp rover k vvc in a dutton s2 as the disks are new and as is 1 caliper ..if someone has had experience that thay are not then i will
look for some GT6 uprights ..as i want to change the hubs pcd to ford i dont want to do it twice
jambojeef
posted on 12/9/13 at 10:06 AM |
I think the version BT is referrring to is available through Canley Classics as a trunnionless upgrade for Spitfire front suspension.
It has integrated brake caliper mounts and a separate steering arm and appears to be the same as that used by Caterham. They sell all the associated
parts and their service is excellent.
A little bit pricey but the parts are of very good quality.
Geoff
posted on 12/9/13 at 10:52 AM |
Canley are a good source of info a specialist Triumph breaker is Quiller
Triumph
Rimmer Brothers still carry a lot of Triumph parts and have a useful illustrated online catalogue
ISTR the Canley front end conversion ran into problems and was discontinued.
Lotus used the the upright on the baby Elan and Europa and the GT6 front upright on other Lotus models from +2 through to the Espirit series
2.
jacko
posted on 12/9/13 at 04:06 PM |
Super Mini Front
I had herald front end on my old grass car the brakes where great.
what you have to watch is the trunions that snap
ask how i know no don't
Jacko
theprisioner
posted on 12/9/13 at 05:02 PM |
Are Spitfire uprights not used as standard on Catering Vans? and J15's etc
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
posted on 12/9/13 at 05:57 PM |
Caterham currently use a version of the Alford & Adler upright with separate calliper bracket and steering arm but the Herald/Sptifire
size stub axle.
The bottom end is machined to accepte a spherical bearing in place of the trunnion.
At some point in the Lotus/Cateringham history the one piece cast Herald/Spitfire part was probably used.
Incidentally the original upright on the very early Lotus Seven S1 was a Hillman Minx part.
40inches
posted on 12/9/13 at 09:26 PM |
Spitfire Graveyard in Sheffield is a good source, and a nice bloke.
spiderman
posted on 12/9/13 at 10:33 PM |
Still available.
http://www.canleyclassics.com/?xhtml=xhtml/product/catkit1.html&xsl=product.xsl
Oil the front upright trunions and don't use grease they will last much longer.
A good forum for Triumph related stuff can be located at "Club Triumph" very helpful and knowledable about all things Triumph.
Spider
