Author: Subject: where to secure an exhaust .
nick-york
posted on 21/9/13 at 05:26 PM Reply With Quote
Hi all ! Just wondering if anybody can let me know where i can find some pictures of exhaust mountings ? The manifold goes over the top of the chassis rail. Cheers !
big-vee-twin
posted on 21/9/13 at 05:36 PM Reply With Quote
I have bolted a strip of 4mm flat bar across the bottom of my chassis - half the width it sticks out beyond the side by about 150mm on top of this is mounted a rubber bobbin which the silencer bolts too.
Originally just had it bolted to outer bottom chassis rail but it wasn't strong enough.
I am just outside York on the 1079.
http://www.triangleltd.com
nick-york
posted on 21/9/13 at 06:19 PM Reply With Quote
hi ! That sounds good to me . Also where the manifold crosses the chassis rail is that just freestanding with nothing but fresh air round it ? I've looked on your photo archive and it looks like to me. But i may be wrong.cheers
big-vee-twin
posted on 21/9/13 at 06:29 PM Reply With Quote
Yep the exhaust is supported by the manifold bolts.
nick-york
posted on 21/9/13 at 06:44 PM Reply With Quote
nick-york
posted on 21/9/13 at 07:15 PM Reply With Quote
That was not to come up on here twice ! Thanks for the advice big- vee - twin !
jacko
posted on 21/9/13 at 07:29 PM Reply With Quote
Dash / wind deflector
You can just see mine, it bolts under the floor and comes up the side 25mm then outwards for a bobbing in the 25mm i have a bolt in the side of the chassis using a rivnut
Jacko
Daddylonglegs
posted on 21/9/13 at 10:10 PM Reply With Quote
Did mine similar to big-vee-twin:
HTH
nick-york
posted on 22/9/13 at 09:44 PM Reply With Quote
Thanks for the pictures ! And from what i can see the exhaust manifold is attached to the engine and the rest of the exhaust is supported by a bracket near the silencer .is that correct or have i missed something ?
