Author: Subject: Aluminium Trumpets, is it feasible?
Cadburys Man
posted on 3/10/13 at 03:14 PM Reply With Quote
Could i fit ally trumpets on my ZX9-R carbs and if so is it a daft idea due to poor filtering or incase of rain?
Daz.
Stuart Taylor ZX9-R Locosaki
puma931
posted on 3/10/13 at 03:31 PM Reply With Quote
Take a look at Dan ST Engineering as they have them for bike carbs.
ianm67
posted on 3/10/13 at 03:32 PM Reply With Quote
Carb trumpets
Carb trumpets are a great idea. They smooth air flow into the inlet port and also increase the speed of the airflow. They are generally used in conjunction with an air box / plenum or sausage filter.
Always biting off more than I can chew.....
mcerd1
posted on 3/10/13 at 04:00 PM Reply With Quote
whats wrong with a set of ZX9R trumpets ?
the std. ones can be got second hand quite cheaply and fit perfectly with no mods
ok they are not that great to look at next to the alloy ones, but they should be inside your filter or airbox so no one will see them
my model 'E' carb's:
[Edited on 3/10/2013 by mcerd1]
FASTdan
posted on 3/10/13 at 04:11 PM Reply With Quote
Thanks for that :-)
There's nothing wrong with the standard trumpets but they are a little short and often carbs come without them. Then you have the task of identifying and sourcing which ones will fit your model carbs - given there are 2-3 variants of several of the popular carbs (including ZX9R) this is not always easy. Hence we developed a few kits to suit the popular carbs, allowing fitment of aluminium trumpets in varying lengths.
They can also have a Pipercross filter integrated so you get the best of both worlds.
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
Cadburys Man
posted on 3/10/13 at 04:13 PM Reply With Quote
Sorry it's me being thick as i thought they took place of the pipercross and would protrude out of the bonnet and would be seen :-/ lol so yeah there's nothing wrong with the standard ones in that case as they aren't even seen like u said, blonde moment haha.
Daz.
