New Topic New Reply
Author: Subject: Is there such thing as a flexible grommet?
cloudy
posted on 9/10/13 at 07:11 PM Reply With Quote
I'm looking for a "flexible grommet", something like a grommet crossed with a steering rack gaiter - but only needs to cope with very small vertical movement
Anyone know of a product that might do the job?
I've drawn the sort of thing i'm after:
This is pretty close, but I suspect too large, I'm looking for an entry hole around 40-50mm with an internal hole of 20mm ish
MG CLUTCH GEAR STICK LEVER GAITER RUBBER MGB 1962-74 22H1337, 4G8
www.warnercars.com
loggyboy
posted on 9/10/13 at 07:20 PM Reply With Quote
Gland and witches hats or bulkhead grommets are names ive seen.
How big do you need?
Original 2"' (52mm) Lucas Black Rubber Bulkhead Grommet : Part No. 54959921
Mistral Motorsport
cloudy
posted on 9/10/13 at 07:27 PM Reply With Quote
Spot on with that link! Thanks very much
www.warnercars.com
big_wasa
posted on 9/10/13 at 07:33 PM Reply With Quote
They make them
cloudy
posted on 9/10/13 at 07:48 PM Reply With Quote
big wasa - any idea what I should search for or what those are called?
www.warnercars.com
NigeEss
posted on 9/10/13 at 08:23 PM Reply With Quote
Firewall boot
Spiral Wiring Gland ?
big_wasa
posted on 9/10/13 at 08:50 PM Reply With Quote
No, is it a one off you need or multiples for a project ?
iank
posted on 9/10/13 at 09:27 PM Reply With Quote
"Stepped Grommet" is closest
https://www.google.co.uk/search?q=stepped+grommet&tbm=isch&tbo=u&source=univ&sa=X&ei=hMlVUqSUJ-ir0gWp74B4&ved=0CEQQsAQ&biw =1745&bih=968&dpr=1
Anonymous
Andy S
posted on 9/10/13 at 09:50 PM Reply With Quote
Or just google image rubber bellows or bellows grommet
[Edited on 9/10/13 by Andy S]
bi22le
posted on 9/10/13 at 10:05 PM Reply With Quote
I hear the voices of the LCB.
It says "easy!"
Please read my ring story:
Rod Ends
posted on 10/10/13 at 02:39 PM Reply With Quote
sleeved grommet?
owelly
posted on 10/10/13 at 03:01 PM Reply With Quote
http://www.mossexpress.co.uk/stepped-grommets-570468
http://www.ppcmag.co.uk
posted on 10/10/13 at 03:04 PM Reply With Quote
Some cars have something similar where the steering shaft goes through the bulkhead.
But if you want a really flexible multi use grommet try LINK
New Topic New Reply
