Browser
posted on 14/10/13 at 12:54 PM |
One for the chainsaw owners
I've just had a replacement for my Ryobi RCS2040 chainsaw as the motor had failed at less than a year old. Trouble is, I got it back with a full
chain oil tank, puty it in the shed and didn't use it at all, went to move it aside the other day and it's pi55ed most of it onto the shed
floor! Having taken the side cover off I can see the end of the feed hose from the lubricator trhough a hole in the chain bar and I can remember tehre
being something in the bar on teh last one blocking my view. Looking on the 'net it seems the petrol ones have a felt washer or some sort of
seal to stop the oil pi55ing out, can anyone confirm this please?
mark chandler
posted on 14/10/13 at 02:53 PM |
Mine does that, not a Ryobi so I drain it down when putting away.
I think you will find this is usual with all makes, the oil feed is just capillary not pumped so will eventually deposit oil unless you lay on its
side.
Regards Mark
posted on 14/10/13 at 03:14 PM |
I bought a cheap saw and it has a piece of foam/sponge over the end where it feeds into the bar. My Husqvarna has a proper pump though but I still
drain the oil and run the fuel out for any long term storage.
Browser
posted on 16/10/13 at 06:45 PM |
Well, been the tool dealers today and they took a look at a Ryobi petrol saw and it's the same as mine, gravity fed and an open end to the oil
hose, so it is obviously ust mean to pee oil out when not in use unless you drain it out, odd, as I don't remember the old one doing it? Ah
well, it's empty now and going on fleabay as soon as I get back from me hols
