Author: Subject: crossflow help needed
nick-york
posted on 23/10/13 at 08:02 PM Reply With Quote
Hi ! im hoping to have my engine running by christmas so planning ahead !The trouble is that it has been sat around for maybe 5 or 6 years . Its been stored undercover while ive owned it but i suppose its still been exposed to some damp to some degree. So is there anything i can do to make sure it will physically turn over when the time comes ? I dont want to be doing anything to it which might damage it so im after a bit of advice from you lot again ! I think ive read somewhere on here about pouring oil down the spark plug holes but cant find the thread . So i might be wrong about that !cheers .
unijacko67
posted on 23/10/13 at 08:16 PM Reply With Quote
You could spray a bit of wd40 down the plug holes while turning it over, it might just help remove any slight surface rust from the bore's if there is any. Do you intend a re-build or is it ready to go. If its ready ish to go I wouldn't clog it up with too much oil at this stage as you will be frapping it up soon.
http://www.kittenkitcar.co.uk
posted on 23/10/13 at 08:24 PM Reply With Quote
You need to turn it over by hand, odds are it will be very stiff or even sized take the plugs out and soak the bores with Plus Gas first, work the crank throughh a few degrees in both directions even if it only moves a fraction of a degree don't use excessive force
unijacko67
posted on 23/10/13 at 08:52 PM Reply With Quote
Yeah, sorry don't wizz it over with the starter. By hand and take time to not get any heat into it until its good and free.
nick-york
posted on 23/10/13 at 09:18 PM Reply With Quote
Originally posted by unijacko67
You could spray a bit of wd40 down the plug holes while turning it over, it might just help remove any slight surface rust from the bore's if there is any. Do you intend a re-build or is it ready to go. If its ready ish to go I wouldn't clog it up with too much oil at this stage as you will be frapping it up soon. As far as i know the engine has been stripped down and rebuilt.
nick-york
posted on 23/10/13 at 09:21 PM Reply With Quote
Thanks for the help !roll on christmas !!
unijacko67
posted on 23/10/13 at 11:25 PM Reply With Quote
I Hope it all goes well. Ford crossflow was the first car engine I built (27 years ago, poo I'm OLD), 1700cc 711M with a piper 285 camshaft and offset dowels to get the cam timing perfect. Good times.
Keep us posted.
JeffHs
posted on 24/10/13 at 08:09 AM Reply With Quote
If the clutch is still fitted, chances are it's stuck to the flywheel so I would pull it apart before fitting it to the car.
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
Building: Run 2 ltr Black Top in single seater race car.
posted on 24/10/13 at 05:42 PM Reply With Quote
When I have to lay and engine up I usually put fusous oil in the system, but probably a bit late in this case. This oil is normally pumped through the injection system bu also works in the bores......
nick-york
posted on 24/10/13 at 10:06 PM Reply With Quote
Hi ! The engine and gearbox are already fitted .So if the clutch is stuck is there another way of freeing it without taking the gearbox off ? - nick
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
posted on 25/10/13 at 08:58 AM Reply With Quote
You need someone to depress the clutch pedal/lever and a long thin screwdriver through the release bearing hole should do it. Had this with a Westfield that had been stood quite some time.
nick-york
posted on 25/10/13 at 09:17 AM Reply With Quote
Cheers ! Easier than taking gearbox off !
JeffHs
posted on 25/10/13 at 09:34 AM Reply With Quote
I've had it happen several times with cars that have been standing. They've always come unstuck eventually by resorting to trying to start the car in gear with the brakes on. Worst one was a Mini that had been sat for 3 or 4 years. It took ages but finally went with a bang. Car was then put back on the road with no further work apart from oil change and went on to do 10,000 miles as a daily hack.
