Author: Subject: wiring fog light switch (help needed)
stevem427
posted on 28/10/13 at 08:03 PM Reply With Quote
Hi. Can some one explain to me how to wire my savage fog light switch please. Its the square one. The diagram I got with it I don't understand. It has four pins on the back and a spade terminal each side. Ive got the supply wire to the switch and the wire to the fog. On the diagram it says:
Position 1=Pins1,2,3made
Position 2=Pins3,5made.
Electrics arnt my strong point. Cheers Steve.
mad4x4
posted on 28/10/13 at 09:15 PM Reply With Quote
Guess
Position 1 = ON
3 Supply (Dipped Beam ON )
1 to Indicator Bulb on Dash which is to ground
2 Out to Fog and Fog is to Ground at Lamp
Position 2 = OFF
May want to consider a relay as well ?
Scot's do it better in Kilts.
renetom
posted on 29/10/13 at 08:33 AM Reply With Quote
Hi
This is how we have ours
works fine without relay & conforms to IVA
good luck.
stevem427
posted on 30/10/13 at 07:22 PM Reply With Quote
Thanks for the replies. Now wired up and working.
Steve.
[Edited on 30/10/13 by stevem427]
