Author: Subject: Do we need a swirl pot?
pekwah1
posted on 31/10/13 at 02:01 PM Reply With Quote
Hi Guys,
Now i understand the concept of a swirl pot, but are they actually required?
I will be fitting a 2.0 zetec on standard ECU and injection, do i NEED a swirl pot, or would a single high pressure fuel pump straight from tank to inlet be ok?
blakep82
posted on 31/10/13 at 02:08 PM Reply With Quote
it would be ok without one, but you'd risk the pump running dry if the level is low in the tank, and misses the tank outlet under cornering for example.
the other option is to have a small sump fitted to the bottom of the tank, say, 3" diameter, but fed by a 1.5" hole (so its got a rim round the outside, fuel goes in by gravity, but doesn't come out again under cornering when the fuel levels low, that way you can use a single pump
https://www.facebook.com/photo.php?fbid=10151870656419739&l=e7e161cbe0
photo of how mine is done^
________________________
loggyboy
posted on 31/10/13 at 02:13 PM Reply With Quote
For tootling round town - no.
fast road or track use - definately.
Mistral Motorsport
pekwah1
posted on 31/10/13 at 02:14 PM Reply With Quote
fair enough, sounds pretty conclusive, i'll chuck one in!
Any recommendations for a cheapish solution?
I'm going to need the pot and both pumps!
loggyboy
posted on 31/10/13 at 02:20 PM Reply With Quote
2 options
Gravity fed swirl pump in/under tank, high pressure pump to engine.
low pressure pump from tank to swirl pot (in engine bay?), high pressure pump from swirl to engine.
Mistral Motorsport
pekwah1
posted on 31/10/13 at 02:22 PM Reply With Quote
thanks, yeh i know the options, not sure exactly what to buy!
so any recommendations on actual hardware would be appreciated!
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 31/10/13 at 02:29 PM Reply With Quote
Subscribing to this thread because I too need a swirl pot and a low pressure pump....
Maybe we can get a deal for a pair of them??
ianm67
posted on 31/10/13 at 03:34 PM Reply With Quote
I am putting a Zetec into my Dax. I am using the GBS inlet plenum with a standard fuel rail and injectors
I bought one of these:
http://www.ebay.co.uk/itm/ALLOY-FUEL-SWIRL-POT-TANK-1-5-LTR-MIRROR-POLISHED-/370340383080?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item563a01c968
And one of these:
http://www.ebay.co.uk/itm/290953172265?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
And one of these:
http://www.ebay.co.uk/itm/Electronic-automotive-fuel-pump-solid-state-Facet-Style-/370931453829?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item565d 3ccf85
Whole lot for less than a ton....
I was fortunate to have an FPR and high pressure filter lying about but it's still a cost effective fuel delivery solution...
Always biting off more than I can chew.....
JohnH
posted on 31/10/13 at 05:45 PM Reply With Quote
My fuel tank has a small swirl tank on the bottom of it,short pipe onto the pump,then straight to the standard ford rail. That's on my 1.8 blacktop zetec with a Spencer Ashley plenum..."........
S2kPower
posted on 1/11/13 at 09:07 AM Reply With Quote
Contact these guys, they make very good quality swirl pots for a pretty low amount
Can't remember what it was as I last spoke to them in July for some work on my S2000
http://www.t6welding.co.uk/
