Author: Subject: Sierra Steering Column Mounting
SALAD
posted on 31/10/13 at 07:46 PM Reply With Quote
I didn't like the size if the mounting holes in the column mount so I looked at four Sierras today to see if there was any kind of top hat bush in the upper mount, but none of them were mounted with anything other than an M10 bolt and thick washer.
So I have mounted mine the same....is this ok or should I make some bushes? I know someone on here did on theirs.
Smoking Frog
posted on 31/10/13 at 08:08 PM Reply With Quote
If it's like that originally then it must be OK. But I also didn't like this and used bigger diameter bolts.
big_wasa
posted on 31/10/13 at 08:21 PM Reply With Quote
I also didn't like it so made some top hat bushes but from the factory its just some big washers.
SALAD
posted on 31/10/13 at 08:24 PM Reply With Quote
OK cool, I'll leave it as it is for now, can always put bigger bolts in or make some bushes later.
Edwardo
posted on 31/10/13 at 11:27 PM Reply With Quote
There is someone on Ebay doing collars for this exact issue now:-
Ebay Link
I had already fitted spacers and large thick washers before he started selling these though otherwise I would have had a set.
Tony
T66
posted on 1/11/13 at 07:50 AM Reply With Quote
I made a pair of bushes, for £7 I need not have bothered ......
