Author: Subject: C20xe clutch and small bore master cylinder
donn006
posted on 7/11/13 at 11:10 PM Reply With Quote
Hi I'm looking for the best place to get a c20xe to type nine gearbox clutch ,,,and a small bore master cylinder ,, and also a set of wing mirrors
Ben_Copeland
posted on 8/11/13 at 01:15 PM Reply With Quote
You need a mixture of clutches for xe to type 9
Xe pressure plate, xe bearing and sierra diesel friction plate I believe
If you haven't got any of those bits then yukspeed is usually the place to ring.
Ben
Locost Map on Google Maps
Enter Your Details Here
