nick-york
posted on 10/11/13 at 01:51 PM |
clevis pin help
2 clevis pins for the top shock absorber brackets at the front ! If you don't have any do you know where i could get some from ? The only ones i
can find locally are too small . I assume the diameter size to fit inside shock absorbers must be the same . I can find out exact length tomorrow
night. But if anybody has a pair taken off a book Ron champion then they would definitely be the right length . Cheers !
posted on 10/11/13 at 03:00 PM |
I know older series Land-Rovers use clevis in the shock absorber mounts but you really should use bolts as any lost motion in the damper mounting
will really have major effects on the handling.
nick-york
posted on 10/11/13 at 06:37 PM |
I tried to use a bolt first but there is not enough room to get a long enough bolt through to
have enough thread sticking out the other end to get a nut on unfortunately . So i suppose the alternatives would be to move the shock absorbed
brackets to a more accesable position or use a clevis pin. So I've chosen the easier option.
