Author: Subject: engine revs
roohunter
posted on 17/11/13 at 09:03 PM Reply With Quote
engine revs
Hi Folks
Bit of a strange one , so here goes,,,
How do you stand for theIVA If you have an engine that has been built to achieve its power at a lower rpm than if standard ? Do they still take is been a standard engine for the test or can you have a letter from the engine builder to show ( supercharged zetec )
Cheers all
Roo
madteg
posted on 17/11/13 at 09:16 PM Reply With Quote
From memory they only take it up to 4000rpm anyway. So no problem.
adithorp
posted on 17/11/13 at 09:32 PM Reply With Quote
On the IVA form you tell them the revs at which the engine makes max' power. This is ONLY used to calculate the revs at which they do the noise test (3/4 of that figure).
If you don't give them a max power revs figure then they do the noise test at 2/3rds of max revs.
If your figure is noticeably low compared to others they've seen you might be asked to explan and a letter from the engine builder might help.
http://jpsc.org.uk/forum/
snapper
posted on 18/11/13 at 01:33 PM Reply With Quote
A supercharged Zetec may cause more noise from the charger than the exhaust at noise check
Be aware of this
I eat to survive
I drink to forget
roohunter
posted on 18/11/13 at 03:23 PM Reply With Quote
noise
Thanks for that ,i didnt think about that ? this could be a complicated job !!!
Roo
