posted on 21/11/13 at 12:51 PM |
welding to a chrome vanadium socket?
I need a 21mm offset ring spanner to dismantle a mcpherson strut. All the local tool people I've tried would have to order one in and
they're not cheap.
I've got a spare 21mm socket and plan to weld a bar onto it to make suitable tool. The socket is polished, but I would flap wheel it to give a
good clean surface to weld to.
Is there any issue MIG welding to chrome vanadium steel?
ashg
posted on 21/11/13 at 12:59 PM |
Just take it to a local garage and get them to undo it with a rattle gun.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
v8kid
posted on 21/11/13 at 01:10 PM |
they're not cheap.
No issues will weld perfectly I've done this a few times. If tight for space you can cut socket with a thin grinding wheel to remove 1/2"
drive section.
Cheers!
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a
chainsaw
Bits are at home in the garage, need to finish the work tonight so I can drive it tomorrow!
Plus I refuse to be defeated
posted on 21/11/13 at 01:13 PM |
they're not cheap.
drive section.
Cheers!
I actually need the height and will be welding to the side of the socket as I need to be able to access the hex drive through the socket into the top
of the Mcpherson strut...
mcerd1
posted on 21/11/13 at 01:20 PM |
it'll weld, but it might not last long (i.e. you could end up with a brittle weld depending on the wire you use etc...)
try shaping the end of the bar before you weld it on to spread the load over as much weld as possible.
my dad's got quite a few special tools made from sockets that have something wrapped round the socket then braised together and they've
all lasted quite well
or how about one of these for ~£6
http://www.ebay.co.uk/sch/i.html?_trksid=p2054897.m570.l1313.TR0.TRC0.XRing+Spanner+21mm&_nkw=Ring+Spanner+21mm&_sacat=11700&_from=R40
posted on 21/11/13 at 01:27 PM |
Good comment, I'll use 25mm RHS and fishmouth it around the socket.
As above, need a fix tonight!
iank
posted on 21/11/13 at 01:46 PM |
Be extra careful not to breath any fumes while welding. Chrome compounds are very bad for you.
Anonymous
loggyboy
posted on 21/11/13 at 01:55 PM |
I might have a21mm dropped ring spanner, will have to check but if you can wait till 6pm you can borrow (if you still work in bstoke?). Not
100% I do have a 21, but pretty sure the set I have doesnt stop at 19mm
EDIT - just rang the wife and asked her to check, the largest she can find is 19. HOWEVER after racking my brains, as I did this on my clio only a few
months back - there maybe another route for you. I have a 21mm sparkplug socket, which has an external hex drive around the rim. Providing your allen
key is long enough, you can thread it through the socket drive and use a larger spanner (or adjustable) on the outside of the socket.
[Edited on 21-11-13 by loggyboy]
Mistral Motorsport
Davey D
posted on 21/11/13 at 02:11 PM |
Is it for a Vauxhall by any chance?
i did exactly the same when it came to changing a front spring on my 05 Astra estate. didnt have a 21mm deep ring spanner, so just welded some 30x10
flatbar onto a 21mm socket to make a handle, so i could put the Allen Key through the middle ![](/images//smilies/bigsmile.gif)
mcerd1
quote: Originally posted by loggyboy
...I have a 21mm sparkplug socket, which has an external hex drive around the rim. Providing your allen key is long enough, you can thread it through
actually I've done that one before too, but I'd completely forgotten about it until you said that - i must be getting old
posted on 21/11/13 at 02:48 PM |
Cheers Loggy - that would do it!
I can make my allen key fit down the hole using the long end and the handle of my adjustable spanner to drive the short end.
I'll be leaving work about 6pm anyway so if it's OK I can call round on the way home?
posted on 21/11/13 at 04:46 PM |
I did this years ago for an alternator pulley nut tool, I still use it for BMW struts, just grind the chrome plating off grind a very slight chamfer
round the edge and aad fairly substantial bit of flat bar on the top welded round the circumference of the socket , finally drill a hole in the bar
for the allen key.
In my experience using a drop spanner is unlikely to work as it will either not fit in the recess or coggle off sideways.
The ideal tool for the job is "drive through socket"
Are you 100% sure the nut is 21mm across the flats because if it is 22mm a Lambda sensor spanner will fit and these are fairly low cost.
[Edited on 21/11/13 by britishtrident]
v8kid
posted on 21/11/13 at 05:05 PM |
Nope it worked perfectly for me twice! The addition of the chrome seems to make the weld flow nicely. IIRC I used a stick welder to whack the current
in and I used it to unbolt a crank pulley and adjust camshaft timing in situ so it was well abused
Interestingly I recently reclaimed one of the sockets by cutting it off again and it works perfectly with a 1/2" drive - and it was red hot when
I welded it.
Dunno if that's a characteristic of chrome vanadium in general or not - I seem to recall summat about the high temp performance of vanadium
steels anyone know offhand?
Cheers1
chainsaw
posted on 21/11/13 at 05:55 PM |
You may well be right, it's a nylon lock nut, but it's that corroded on it will take a substantial amount of force to free it. I only
want to retrieve the bump stop and gator to fit on the new shock.
mcerd1
posted on 22/11/13 at 12:16 AM |
I'm only saying not to expect it to be perfect when you weld a socket of unknown grade to a bar of unknown grade with a random bit of mild steel
welding wire using whatever gas you've got
when your welding some dissimilar metals together the welds can end up very weak, very brittle or both....
