New Topic New Reply
Author: Subject: Removal of number plate sticky pads - what is best?
martyn1137
posted on 10/12/13 at 09:54 PM Reply With Quote
I have to change some number plates. Existing are stuck on with the useful sticky pads which saves drilling lots of holes in the car, but residue is a pain to shift. In the past I have carefully scraped off what I can then attacked the rest with an old can of paint thinners I have kept just for this purpose. It still takes ages and is mighty messy.
Anyone have success with anything else?
loggyboy
posted on 10/12/13 at 09:58 PM Reply With Quote
Hair dryer and your thumb just take it easy, heat and friction add up to easy blisters.
Mistral Motorsport
owelly
posted on 10/12/13 at 10:01 PM Reply With Quote
'Sticky Stuff Remover Gell' or a Toffee wheel.
http://www.ppcmag.co.uk
AndyW
posted on 10/12/13 at 10:05 PM Reply With Quote
+1 for toffee wheel, brill bit of kit...
ceebmoj
posted on 10/12/13 at 10:20 PM Reply With Quote
Baby oil is very good as a sticky stuff remover.
dunk3
posted on 10/12/13 at 10:28 PM Reply With Quote
WD-40
daviep
posted on 10/12/13 at 10:34 PM Reply With Quote
Just leave the old and stick new ones next to them
posted on 10/12/13 at 11:19 PM Reply With Quote
Hand held steam cleaner or near boiling water
Don't use anything oily the residue will stop the new pads sticking.
Number plates take a bit of practice to put on straight and centre properly
Better to for get about the pads and use proper coloured number plate screws --- drill and fix one screw then adjust the plate until it is properly level, double check standing a few feet back from the car before drilling the second hole.
Andybarbet
posted on 11/12/13 at 12:22 AM Reply With Quote
White spirit usually clears sticky stuff, then finish off with some degreaser.
NigeEss
posted on 11/12/13 at 12:56 AM Reply With Quote
Scrape off with a sharp wood chisel and remove the sticky bit with brake cleaner.
martyn1137
posted on 11/12/13 at 01:25 PM Reply With Quote
Thanks everyone, I have a few things I can try there.
Fred W B
posted on 13/12/13 at 12:45 PM Reply With Quote
Handy stuff to remove sticky residue from hard surfaces you don't want to damage is Brasso metal polish.
Wipe it on, leave for a minute and then polish off.
Fred W B
[Edited on 13/12/13 by Fred W B]
New Topic New Reply
