nick-york
posted on 30/12/13 at 09:25 PM |
propshaft wanted
Hi . Im after a propshaft to fit a cortina diff and a cortina 4 speed gearbox please? The distance between the two flanges is 80.5 cm .Hopefully
somebody will have one they don't need .
slingshot2000
posted on 30/12/13 at 09:39 PM |
Hi Nick, there is one in my garage. It is out of my early Westfield, which is fitted with a Type E Four-Speed Box and an Escort diff.
I am certain the flanges are the same, but will check and make sure. I will also measure the length in the morning if you think it is any good.
nick-york
posted on 30/12/13 at 09:52 PM |
thanks ! That's great ! Hopefully it will fit. Then we can agree on a price. Cheers !
teegray19
posted on 30/12/13 at 10:08 PM |
I've got one too, just come off the car cheers.
nick-york
posted on 30/12/13 at 10:59 PM |
ooh just hold on to it ! If slingshots won't fit then maybe yours would . I ll
be finding out sometime tomorrow hopefully . Cheers - nick.
slingshot2000
posted on 31/12/13 at 01:41 PM |
Hi Nick,
I have just been and measured the prop-shaft and it is 84.0cm, from the flange to the very end of the part that slides into the back of the gearbox.
When you said 80.5cm between the flanges, where exactly were you measuring from/to ?
Regards
Jon
nick-york
posted on 31/12/13 at 02:04 PM |
Hi Nick,
Regards
Jon
hi Jon . When i measured i didn't measure the distance inside the gearbox end so that explains why your measurement is larger. Im
going to the car now so i ll have another measurement and maybe some photos.it ll be about 20 min till im at the car . Cheers !
slingshot2000
posted on 31/12/13 at 03:07 PM |
u2u sent with contact numbers.
nick-york
posted on 31/12/13 at 03:14 PM |
Hi Jon ! I've been a while because I've spotted a potential problem ! I've got the 'original' propshaft from the donor
cortina 1600e and thought id slide it onto the gearbox end to see how far in it went ! But it doesn't want to go in ! So i counted the teeth on
the gearbox end - 16 . With 20 grooves inside old propshaft end ! So could you count the grooves inside the end of your propshaft please ?
slingshot2000
posted on 31/12/13 at 03:53 PM |
Hi Nick,
as discussed on the telephone, mine seems to have 24 splines and is therefore no good to you. It sounds like you have an Escort gearbox with the
Integral Bell-Housing. I am not sure which Escorts thy were fitted to, but there is bound to be someone out there that does know.
Teegray19's may be the one you need, and his is just a little bit further North than me.
Good luck , and let me know how you get on.
Regards
Jon
teegray19
posted on 31/12/13 at 05:12 PM |
Hi, if im npt tied up tomorrow I will count splines measure and u2u! Cheers
nick-york
posted on 31/12/13 at 05:15 PM |
Hi ! Slingshots propshaft has too many splenes so won't fit ! Could you count the
splenes on yours please ?
will121
posted on 31/12/13 at 05:25 PM |
I have one but total length including the part that goes in the gearbox is 96cm 16 spline photos and details in this previous post link
http://www.locostbuilders.co.uk/viewthread.php?tid=166794
nick-york
posted on 1/1/14 at 11:28 AM |
Hi Will ! I've looked at the details of your prop . Just trying to
find out if its the right length .hopefully i ll get to know shortly ! Cheers ! And fingers crossed !
nick-york
posted on 2/1/14 at 07:46 PM |
Hi again ! I think it is a bit too long
and it looks like its got a flange to fit an escort diff. These could possibly be modified but maybe a can of worms ! Thanks for trying to help . -
nick
nick-york
posted on 2/1/14 at 07:49 PM |
hi ! Have you had chance to count the splines and do some
measuring ?
teegray19
posted on 2/1/14 at 09:38 PM |
Il nip over the garage nw and do some measuring.
teegray19
posted on 2/1/14 at 10:17 PM |
Shed keys have been taken out by other half, il go over before work tomorrow and u2u.
nick-york
posted on 2/1/14 at 10:28 PM |
Thanks a lot tegray . Much appreciated . - nick
teegray19
posted on 3/1/14 at 08:06 AM |
Morning, 16 splines 880mm oal.
Ths flange I belive to fit escort/tina etc. Both uj's in good order.
nick-york
posted on 3/1/14 at 08:35 AM |
Morning teegray . Now i think that might be a tadge too long but
not sure . Im going to ring dunning and fairbank and see if they think it needs shortening and if so how much they will charge .I ll let you know when
I've spoken to them . Cheers - Nick .
teegray19
posted on 3/1/14 at 08:40 AM |
what engine are you going for? this fit my kit perfectly.
its actually quite short when you think how much goes in the gear box and how much is uj.
nick-york
posted on 3/1/14 at 10:22 AM |
Its on a 1600 crossflow .Just spoken to dunning and
fairbank . They tell me it would need shortening and the cost for that would be £45+ vat ! I got a price off them yesterday for a brand new one made
from scratch £105+vat . So unfortunately it doesn't work out any cheaper buying a second hand one if it needs altering . I was hoping to buy a
good second hand one that would just fit straight away .Maybe i was been a bit too hopeful. So i ll just have to buy a new one. But thanks teegray and
everyone else for trying to help . Much appreciated. Cheers - Nick
teegray19
posted on 3/1/14 at 11:29 AM |
No probs. As I say it fit really well in my f27 with a crossflow and the same box as your using. Might just need a couple of new engine gearbox mounts
cheaper than that prop!
