corrado vr6
posted on 31/12/13 at 12:05 AM |
Oil pressure sender in R1
Hi there, I'm looking to fit an oil pressure sender unit into my 06 R1 5vy
My mate has one fitted but is unsure on the adaptor thread needed to go into the engine
Here's a pic of where it's located on his R1, does anyone know the thread size for this hole?
This is the back of the engine with the prop just to the right
Many thanks in advance
Greg
http://r1indy7.wordpress.com/
Davey D
posted on 31/12/13 at 08:33 AM |
If it is one of the original oil takeoff points that had a big cap with an Allen key hole (there is one on either side of the engine then it is an m16
adapter that you want. I used am m16 to 1/8th npt adapter. I've got temp sensor in one side screwed directly into the engine, but I've got
my pressure sensor off a length of braided hose, and then rubber mounted onto my chassis to stop it getting wrecked from engine vibrations.
bigfoot4616
posted on 31/12/13 at 10:19 AM |
you definitely want to have it remote mounted, i have read about a few that have failed when they have been mounted like that.
corrado vr6
posted on 31/12/13 at 10:21 AM |
Remote mounted? How do you mean??
Thanks for replies, I have ordered a M16x1.5male adaptor with 1/8 npt for the gauge
bigfoot4616
posted on 31/12/13 at 10:52 AM |
like davey mentions above, on a length of braided hose. i got the remote mount kit to do it from ETB when i bought my dash.
corrado vr6
posted on 31/12/13 at 01:08 PM |
Oh I get you both now, cracking ill get buying
ashg
posted on 31/12/13 at 04:20 PM |
1/8th npt in Metric will be m10 fine if it is truely metric.
[Edited on 31/12/2013 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
