Author: Subject: What electrics should I keep?
mark_UK
posted on 28/10/04 at 09:11 PM Reply With Quote
Apart from the obvious coil,starter,battery etc what should I keep off the XR4x4 donor its the mechanical injection model (I dont need the ABS bits and bobs)
posted on 28/10/04 at 09:43 PM Reply With Quote
Depends Mark whether you're builder Car Engined Car or Bike Engined Car.
Differential (LSD), hubs and shafts
Rear Disc's and calipers (if you prefer disc's)
Front Disc's and calipers
Ignition and Key Mechanism
Steering Column from none PAS (4x4 not required as it's powered)
Steering Rack from none PAS (ditto)
Uprights front and rear not required
Front hubs not required as hollow for front shafts.
As much wiring as possible - we took out the dash to totally scavenge.
Any other info. ask, we're only round the corner...
Ben_Copeland
posted on 28/10/04 at 10:33 PM Reply With Quote
Think he was asking about electrics not the mechanics
Ben
Locost Map on Google Maps
Enter Your Details Here
Jon Ison
posted on 29/10/04 at 08:17 AM Reply With Quote
as much as poss, you can ditch what u dont use later......simple .
posted on 29/10/04 at 08:38 AM Reply With Quote
Ben - I guessed that
You looking at upping your post's again
Ok... CEC or BEC?
Either way don't chuck it until you've got your Kit assembled and preferably on the road... then another few months after SVA...
Just about covers it...
mark_UK
posted on 29/10/04 at 12:32 PM Reply With Quote
Thanks everybody I`ll keep as much as i`ve got room for.Hellfire I think i`ve seen your car ,there cant be that many bright yellow bike engined cars in maltby specially with a tax disc :p
mark_UK
posted on 29/10/04 at 12:34 PM Reply With Quote
forgot to mention its gonna be car engined (V6)
Ben_Copeland
posted on 29/10/04 at 12:55 PM Reply With Quote
Me ???? Never
Ben
Mark Allanson
posted on 29/10/04 at 07:17 PM Reply With Quote
Right again, keep everything you can - you will be amazed what you will use or regret chucking!
