Author: Subject: Book chassis Build still viable?
bluegrass
posted on 10/1/14 at 10:42 AM Reply With Quote
Before I launch into a full Book chassis Ron Champion build with the usual escort mk2 donor bits ...1300 xflow etc.(no v5)....
I just wanted to check with the experienced members...is a standard book build still a viable route to take in terms of getting a car
through the iva tests etc or am I going to find it difficult to get the car on the road once its built?
Thanks for any advice
fesycresy
posted on 10/1/14 at 11:16 AM Reply With Quote
No real difference between IVA and the old SVA (except the money!), so you'll have no problems.
bluegrass
posted on 10/1/14 at 11:19 AM Reply With Quote
Thanks for that. Reassuring to know its still viable.
adithorp
posted on 10/1/14 at 11:27 AM Reply With Quote
No reason it shouldn't be OK for IVA. Just read the IVA manual and build with the reg's in mind. You'll need proof of age for the engine to avoid the tougher emmision test but Ford are quite good at providing that.
http://jpsc.org.uk/forum/
Slimy38
posted on 10/1/14 at 04:10 PM Reply With Quote
There are some very subtle changes for IVA. For example, in the Haynes book it shows a built car that used pipe lagging and four cable ties to cover the exposed lock nuts. This is no longer the case (it's not considered permanent I think?), but I believe a short length of heat wrap sleeving over the lock nuts is fine.
Just glance through the IVA manual and get a feel for how things will need to be, and ask any questions you like on here. I've asked some really bizarre questions and still had an answer from someone who's been there and done it!
mark chandler
posted on 10/1/14 at 04:16 PM Reply With Quote
It's a smaller car, IMHO this is a big plus, just wish I had shrunk mine when building even further.
