Author: Subject: bike indicators
Dooey99
posted on 14/1/14 at 07:56 PM Reply With Quote
bike indicators
could i put bike indicators on the front of my car if they are E marked?
Less weight more speed, more power more speed
If in doubt, give it a clout
big-vee-twin
posted on 14/1/14 at 08:00 PM Reply With Quote
yes, but will need stalks extending to meet IVA spacings i.e. 400mm from edge.
http://www.triangleltd.com
bob
posted on 14/1/14 at 08:18 PM Reply With Quote
I used some plastic conduit to extend mine.
[img][/img]
theduck
posted on 14/1/14 at 08:44 PM Reply With Quote
Spacing is assuming you are putting them on the nose cone of a 7 type car. I haven't had to space mine as they are on the headlight bracket not the nose cone.
Dooey99
posted on 14/1/14 at 08:46 PM Reply With Quote
nice one thanks for the replies i have diagrams for the spacing and hieghts that i go by so hopefully ill get them in the right place
Fozzie
posted on 15/1/14 at 01:31 AM Reply With Quote
I used Ducatti 'Monsters'
loggyboy
posted on 15/1/14 at 08:05 AM Reply With Quote
Lights dont need to be E marked, as long as they emit a similar light to that of an emarked light. (Ie intensity and colour).
Mistral Motorsport
deezee
posted on 15/1/14 at 08:31 AM Reply With Quote
Just to confirm. During my IVA, it was only the headlights and fog that he checked for markings. Said the indicators don't need to be E marked, but if they are, they must be correct for the light.
40inches
posted on 15/1/14 at 09:24 AM Reply With Quote
I used 15mm Stainless plumbing tubing, goes right through the nose cone.
SteveWallace
posted on 15/1/14 at 11:38 AM Reply With Quote
I used bike indicators, copper radiator pipe for the core and then plastic tube from B&Q, sprayed to the right colour for the outer layer. The insulating tape was just to get a tight fit. The wires run through a nut that was hammered and then glued into the end of the pipe. I then drilled a hole through the corresponding bolts to feed the wire through. In that way, I only needed a small hole through the nose cone. The large blue nut is a plastic plumbing part that's cosmetic only.
extension showing captive nut
indicators colour coded
close up of front indicator
loggyboy
posted on 15/1/14 at 12:11 PM Reply With Quote
Apologies, you are right, I should have been clearer. The Rear Fog does indeed need to be E marked (and F or B marked).
However Headlights dont need to be E marked (only Gas discharge/LEDs, which are almost impossible to install on a kitcar.)
Mistral Motorsport
