Author: Subject: Do you need a special primer to paint something zinc plated and yellow passivated?
smart51
posted on 15/1/14 at 03:42 PM Reply With Quote
I've just zinc plated some parts for a recumbent trike I'm making. The orangy yellow colour they've come out doesn't match the nice red colour of the frame, so I want to paint the outer tube the same colour as the frame. Do I need a special primer to stick to the zinc coating or can I use normal primer?
hkp57
posted on 15/1/14 at 03:53 PM Reply With Quote
Smart51 after a period of time any paint on a zinc based surface will flake off unless you use an etching primer first.
emsfactory
posted on 15/1/14 at 04:47 PM Reply With Quote
Yes you do. I cant remember the name of the stuff but you paint it on and the zinc turns black. You can then paint as normal metal.
TrophyJem
posted on 15/1/14 at 05:15 PM Reply With Quote
Mordant solution is what you need.
Turns it black and then it can be painted
BigFaceDave
posted on 15/1/14 at 05:19 PM Reply With Quote
We use some stuff at work called T wash, you just brush it on and it turns black then rince it down and once dry just prime over the top of it.
hkp57
posted on 15/1/14 at 07:51 PM Reply With Quote
Plus one for T Wash
balidey
posted on 15/1/14 at 08:27 PM Reply With Quote
As above, an etch primer is what you want.
And I'm sure most people are aware that zinc plating is a 'line of sight' method, so if you have return bends or box sections on the part you have had plated, there is likely to be bare areas that have not been plated, so worth checking on any hidden faces that need extra treatment. The number of people that look at rust runs coming out of nice shiny zinc plated items and wondering how its possible is quite high.
Dutch bears have terrible skin due to their clogged paws
