Author: Subject: Caterham 6 speed box
ceebmoj
posted on 17/1/14 at 09:58 AM Reply With Quote
Has any one fitted a Caterham 6 speed box? Are thay a straight swap for a type 9?
femster87
posted on 17/1/14 at 11:11 AM Reply With Quote
I believe they are straight swap for a type 9 box
rdodger
posted on 17/1/14 at 02:21 PM Reply With Quote
I thought they had the longer input shaft?
peter030371
posted on 17/1/14 at 02:43 PM Reply With Quote
When I looked into it I am sure they have a 'mid length' input shaft, half way between the short and long shaft. Several people have had to use a 10 or 20mm spacer between the gearbox and bell housing to get the length right.
rdodger
posted on 17/1/14 at 02:55 PM Reply With Quote
Good info here
http://www.jpsc-online.co.uk/viewtopic.php?f=4&t=228
omega0684
posted on 17/1/14 at 04:48 PM Reply With Quote
it aint cheap! if you can get a box for under £2500 you are doing well! also think about ratios and what diff you are going to run with it!
Personally i don't think its worth it unless you are running a bit of a beasty boy under the bonnet!
ceebmoj
posted on 17/1/14 at 04:55 PM Reply With Quote
Thay are not cheap but it looks like there are a fue for sale for around 1300 at the moment. To be honest I wanted to know how had it would be to swap at a later stage as it seams no that bad it can be an upgrade for later.
DH2
posted on 17/1/14 at 05:39 PM Reply With Quote
As suggested, think about the ratios and what your use case is. 6th gear is 1:1, there is no 'overdrive' gear.
DH2
rdodger
posted on 17/1/14 at 06:13 PM Reply With Quote
The perfect box for track with a 3.9 diff. Not so much if driving on the motorway!
Pat_T
posted on 17/1/14 at 09:38 PM Reply With Quote
some of the prices quoted on this thread are bonkers. I got my sequential for £1100, should be able to pick up a Caterham 6spd for about £700 max. just need to know where to look, avoid Ebay...
www.instagram.com/patroclueus
ceebmoj
posted on 18/1/14 at 12:35 AM Reply With Quote
Where did you find the sequential box/ where you recommend looking for a six speed?
