Author: Subject: Type E gearbox Strip
Dangerstevie
posted on 24/1/14 at 07:56 AM Reply With Quote
Morning folks,
I want to remove everything from inside my type e gearbox with the exception of 3rd, 4th and reverse. I am aware that the reverse gear is ran off the 1st & 2nd hub but i am prepared to stick the gear cluster in the lathe and machine the shaft so only the reverse drive is present. My question is (without stripping my box down i don't yet know) would it be possible to literally just remove everything relating to 1st & 2nd, keep the reverse bits and just spacer them up on the shaft to suit?
Paul Turner
posted on 24/1/14 at 03:54 PM Reply With Quote
See here for answers.
http://www.locostbuilders.co.uk/forum/9/viewthread.php?tid=187922
