rash12
posted on 30/1/14 at 09:53 AM |
side repeaters
im sure this has been covered before but where do they need to go for iva test any pics would be helpful
thanks in advance
adithorp
posted on 30/1/14 at 10:22 AM |
Have a read of the IVA manual; specifically the angles of visability bit.
Current interpretation seems to be that if they're on the side or scuttle pannels, then the rear wings obscure them (specifically the 5'
downward angle from the rear bit). Most are passing either fitted to the front or rear arch edges. If you go for the rear, check the max'
distance from the front requirement isn't exceded.
http://jpsc.org.uk/forum/
johnemms
posted on 30/1/14 at 10:24 AM |
![](/galpreviews/Side indicators.jpg) ![indicators](/gallery/Side indicators.jpg) indicators
![](/galpreviews/22Side Repeaters.jpg) ![Description](/gallery/22Side Repeaters.jpg) Description
Only one pair of repeaters to be fitted.
These in the back arch are 100% pass
After IVA I put an extra pair in the headlamp bowl ..
![](/galpreviews/side lights2.jpg) ![Description](/gallery/side lights2.jpg) Description
![](/galpreviews/IMG_20121105_132131.jpg) ![Clear led's in headlight](/gallery/IMG_20121105_132131.jpg) Clear led's in headlight
![](/galpreviews/IMG_20121105_132152.jpg) ![clear LED in headlight](/gallery/IMG_20121105_132152.jpg) clear LED in headlight
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
davidimurray
posted on 30/1/14 at 11:50 AM |
Mine are on the rear arches, but beware there is a max distance from the front of the car which my IVA examiner checked very carefully. His
reccomendation was to put them on the back of the front cycle wings, as being on the rear arches they may meet the rule, but if on the front the
passing driver can see them later.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
snowy2
posted on 30/1/14 at 12:32 PM |
I have seen some headlights on a new manitou telelifter whic include indicators and side repeaters and are mounted from the bottom on a ball
joint.....they dont look bad either.
sometimes you are the pigeon, most of the time the statue.
rash12
posted on 30/1/14 at 08:04 PM |
thanks for the replies back arches look favourite
nick-york
posted on 31/1/14 at 12:50 AM |
hi ! I think that Pstirz on here passed with his side repeaters mounted on the side of his scuttle . If you look in his photo archive you will see the
pictures. That's where im putting mine.
renetom
posted on 31/1/14 at 08:59 AM |
side indicators
Hi
same as Johnemms, was told by our examiner to put them on the rear arches
having failed our first IVA.
Did in fact ask him if they would be ok on the scuttle ,
His reply was yes if you want it to fail again !.
![](/galpreviews/mkr111.jpg) ![items failed](/gallery/mkr111.jpg) items failed
Also failed on the choke cable knob , it was ok for radius , but his testing ball
has a retractable eye socket & it went in that , I could not believe it .
removed it for IVA , put it back on after.
Good luck
gavin174
posted on 31/1/14 at 11:20 AM |
I fitted mine in the front headlights..
passed iva no problem.
![](/galpreviews/a1076248-IMG00186-20100111-1744.jpg) ![Rescued attachment IMG00186-20100111-1744.jpg](/gallery/a1076248-IMG00186-20100111-1744.jpg) Rescued attachment IMG00186-20100111-1744.jpg
