Author: Subject: Locking wheel bolt removal without a key
Nurburg2006
posted on 31/1/14 at 12:29 PM Reply With Quote
Hello guys, what the best way to remove a locking wheel bolt without a key? Weld a nut on Bang a socket on etc. it's on a pug 307 with genuine alloys. Cheers
[Edited on 31/1/14 by Nurburg2006]
Ben_Copeland
posted on 31/1/14 at 12:31 PM Reply With Quote
I usually bang a socket on, My 17mm sockets had a hard life
If you have Halfords life time warranty ones then you don't need to worry about breaking them
Ben
Locost Map on Google Maps
Enter Your Details Here
posted on 31/1/14 at 12:34 PM Reply With Quote
Provided they aren't the type that have a spinning outer shell you can get special sockets to do this that have female eezy-out style thread they only really intended work well with an impact gun but might work with hammer style impact drive.
The socket however wear will only last a limited number number of uses.
Halfords sell them as do most of the online suppliers.
bi22le
posted on 31/1/14 at 12:44 PM Reply With Quote
Dont pay for someone to do it!!
mazie on here did and they damaged his alloy, a right monkey!!!
Please read my ring story:
adithorp
posted on 31/1/14 at 12:55 PM Reply With Quote
Just 'cos that happend to him doesn't mean everyone will do the same.
Either sacrificial 12pt socket knocked on (the knocking helps release it so don't be shy) or a remover as BT describes (but the don't always fit the recess in the wheel). If it has a hardened revolving ring you'll need to drill down between ring and centre (dont slip) then split the ring with a chisel, then it shoult remove as before.
If it's the common Pug' one with 4 small pins to locate, a small diameter raised centre with a shear section and the base almost the same size as the wheel recess... then they're very tricky. Good luck with those!
http://jpsc.org.uk/forum/
loggyboy
posted on 31/1/14 at 01:03 PM Reply With Quote
Get yourself a gator grip.
Mistral Motorsport
Nurburg2006
posted on 31/1/14 at 01:23 PM Reply With Quote
Will a gator grip fit?
loggyboy
posted on 31/1/14 at 01:28 PM Reply With Quote
Its worked for me before, but it depends on the type and size of the bolt, and the size of the hole in the wheel (if its recessed down a hole).
[Edited on 31-1-14 by loggyboy]
Mistral Motorsport
mark chandler
posted on 31/1/14 at 01:29 PM Reply With Quote
You can try one of these things Linky
If I had spare bolts then nut over the top, quick buzz with the welder would be my choice, it's free
Regards Mark
loggyboy
posted on 31/1/14 at 02:00 PM Reply With Quote
Pretty much a gator grip
Mistral Motorsport
adampage
posted on 31/1/14 at 02:12 PM Reply With Quote
This happened to my BMW.....
But got it fixed quite quickly.
First go was chisel off the outer sleeve/ring on the locking bolt, but the hole in which the bolt sits was quite tight, so likely to damage....
Second go was weld on a bolt, jobs a good 'un. Done by a local 'old guy in a rented unit' type garage, great old boy, no damage, charged £45 which I thought was reasonable (they were very very stuck!), happy for him to do it.
Find someone trusted/recommended and you should avoid the bad luck others have had.
Ad
BangedupTiger
posted on 31/1/14 at 02:23 PM Reply With Quote
loosen all the other bolts and take the car for a good thrash, it'll soon come loose.
nludkin
posted on 31/1/14 at 04:21 PM Reply With Quote
Rather than breaking the outer ring with a chisel, you can heat it up by welding onto it. That expands it enough that it just falls off A blow torch would probably work too, but would take most of the paint with it!
Angel Acevedo
posted on 1/2/14 at 03:18 PM Reply With Quote
Sorry for stupid questions, but...
Why are you trying to remove without Key?
Why not post a pic and get a loaner or buy one from the crowd at LCB?
Regards
Angel Acevedo
Nurburg2006
posted on 1/2/14 at 11:17 PM Reply With Quote
It's a mates car trying to help him out
Nurburg2006
posted on 2/2/14 at 02:15 PM Reply With Quote
Job done cheers for all the replies chaps
Angel Acevedo
posted on 2/2/14 at 03:46 PM Reply With Quote
How did you end up doing it?
Thanks.
AA
Nurburg2006
posted on 2/2/14 at 06:12 PM Reply With Quote
Welded a bolt on
