Author: Subject: Has anyone local to Aylesbury got a VAG com/VCDS
ChrisW
posted on 31/1/14 at 02:56 PM Reply With Quote
As subject, need use of a VAG com/VCDS unit. Is there anyone in the local area that has one and would lend it for a few days? Happy to leave a deposit if required.
Thanks, Chris
My gaff my rules
matt_gsxr
posted on 31/1/14 at 07:43 PM Reply With Quote
Not me, but there is map on the audivw.forum
http://www.vwaudiforum.co.uk/forum/showthread.php?134957-VCDS-User-Location-Map
https://maps.google.co.uk/maps/ms?msid=209563024277134815192.0004c505be14b22419dbe&msa=0&ll=56.231139,-2.779541&spn=3.493691,10.821533& ;iwloc=0004c505cfcb6158e0447
Looks like someone in Aylesbury
http://www.vwaudiforum.co.uk/forum/member.php?34928-Cockney-Boy
(unless that is you of course)
the guy in Oxford never replied when I tried to contact him.
Matt
40inches
posted on 31/1/14 at 08:06 PM Reply With Quote
I have a Vag-com RS232 ISO Twin-Com interface, with a USB adaptor (that surprisingly works!)
Don't know how quickly you want one for, but I could post it you down.
ChrisW
posted on 1/2/14 at 02:38 PM Reply With Quote
Thanks guys. Karlak aka Simon has lent me his as the car is stuck on my driveway. Now I just need to find a wiring diagram for the car to work out what the fault actually means!
Chris
My gaff my rules
karlak
posted on 1/2/14 at 06:18 PM Reply With Quote
Any luck Chris ?
What does the scan show up ? Did it show any errors at all ?
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
ChrisW
posted on 1/2/14 at 06:50 PM Reply With Quote
It shows the following. Problem is I've no idea what it actually means!
(Guessing either fuel pump or fuel control module but I don't have either to swap out)
What's worse is that it's still draining the battery when left alone, and even when charged up the battery monitor in the MMI says it's flat.
Think it's going to have to go to Audi. Highly annoying.
Chris
code:
Address 01: Engine (BUH) Labels: Redir Fail!
Part No SW: 4F5 910 552 HW: 4F1 907 552 A
Component: 5.0L V10/4V TFSI ª0080
Revision: F1H05--- Serial number:
Coding: 010D0003190F02B0
Shop #: WSC 00149 210 85453
VCID: E5C4ADFA55E7
1 Fault Found:
012425 - Signal Line for Fuel Pump Electronics: Electrical Malfunction
P3089 - 002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Mileage: 52984 km
Time Indication: 0
Date: 2008.04.03
Time: 13:37:48
Freeze Frame:
RPM: 122 /min
Load: 68.2 %
Speed: 0.0 km/h
Temperature: 3.0°C
Temperature: 5.0°C
Absolute Pres.: 980.0 mbar
Voltage: 9.779 V
Readiness: 0110 1101
My gaff my rules
karlak
posted on 1/2/14 at 06:57 PM Reply With Quote
oh dear
Seems their fault code page agrees. Does the fuel pump "spin up" on ignition ?
http://wiki.ross-tech.com/wiki/index.php/19545/P3089/012425
matt_gsxr
posted on 1/2/14 at 07:34 PM Reply With Quote
Regarding wiring diagrams and such you can buy electronic access to everything from this site:
https://erwin.audi.com
You can't download stuff in bulk, but it isn't expensive and you can get screen shots.
Sorry if you know this already.
ChrisW
posted on 2/2/14 at 07:43 PM Reply With Quote
Thanks! I didn't know about that.
Chris
My gaff my rules
