Original Mini Parts for Sale
Bought a mini a few years ago to restore, and modify. But due to having far too many interests, and projects i ended up selling the mini end of last
year. So i have a load of new parts taking up space in the garage i need to clear out.
Each part has a price, and a part number, so you can look them up on minispares.com. would prefer collection by buyer of the body panels due to
potential of damage through post.
SILL PANEL OUTER L/H MK3 ON GENUINE 14A9535 £24
SILL PANEL R/H OUTER MK3 ON GENUINE 14A9534 £24
A PANEL MK3 R/H GENUINE ALA5660 £15
A PANEL MK3 L/H GENUINE ALA5661 £15
DOOR STEP PANEL ALL MODELS GENUINE ROVER BHM13 £20
DOOR SKIN MK3 RH WIND UP WINDOW TYPE DOOR GENUINE CZH3300 £52
WING FRONT WITH SIDE REPEATER HOLE R/H 1988 TO 1996 GENUINE BMP454 £66
WING FRONT WITH SIDELAMP AND AERIAL HOLE L/H 1988-96 GENUINE BMP455 £66
WINDSCREEN SURROUND LOWER PANEL REPAIR GENUINE HMP441001 £86
FRONT PANEL 1976->1996 GENUINE ALA8619 £113
JACKING POINT L/H & CROSS MEMBER EXTENSION REPAIR GENUINE 14A8375 £10
JACKING POINT R/H & CROSS MEMBER EXTENSION REPAIR GENUINE 14A8374 £10
WINDSCREEN CORNER SUPPORT PANEL R/H PATERN MS6XR £6
WINDSCREEN CORNER PANEL R/H PATERN MS6R £7
Pair of Refurbished as new lower arms Fitted with New Poly Bushes + New tie bar with rubber mounts 21A1882MS & 8G4249 £30
Genuine Hi-Los + Gas Uprated Kayaba Dampers MSS3003 £130
Rear Subframe Bolt + Bush Fitting Kit MS43 £20
Subframe Mounting for rear of front subframe (Pair) 21A2599MS £3
Subframe Mounting for front of front subframe (Pair) 21A2624MS £3
Front Bump Stop under top arm (Rebound buffer) (Pair) 2A4267MS £3
Steering Rack Gaiter Pair 4.5” Long BHM7113 £8
New shape Poly Bump stop 1976 onwards (single bolt) (pair) FAM2764MS £5
Swivel Pin Kit Ball joints (Pair) GSJ166MS £10
I also have a box of bits that ive taken off the original mini, like brackets, fixings, handbrake, steering column, window winding mech, front, and
rear windscreen etc etc. If there are any parts you need, then ask the question, and ill see if i've still got it.
