Author: Subject: What Is It With Cooker Hood Bulbs!!!!
Surrey Dave
posted on 5/3/14 at 07:15 PM Reply With Quote
They seem to blow about once a month and take the 3 amp fuse with them.
I blame Poundland!!!
I've been told that if you fit the bulbs that have a halogen built inside they are not affected by the heat so much?
True /False ....Any offers!
[Edited on 5/3/14 by Surrey Dave]
Smoking Frog
posted on 5/3/14 at 07:22 PM Reply With Quote
I don't know about the halogen ones but I've changed mine twice in the past month, must be poor quality batch.
T66
posted on 5/3/14 at 07:24 PM Reply With Quote
New kitchen recently , new oven ......
oven bulb lasted 3 days
steve m
posted on 5/3/14 at 07:34 PM Reply With Quote
mine is still fine after 10 years,
so not sure what you lot are doing wrong
whitestu
posted on 5/3/14 at 07:35 PM Reply With Quote
I changed mine for low energy ones in our old hood and they were still working when we binned it.
gremlin1234
posted on 5/3/14 at 07:36 PM Reply With Quote
False, cooker hoods don't run hot,
they may have some vibration from a fan which would shorten the life of any bulb,
but bulb quality is the primary suspect here.
ReMan
posted on 5/3/14 at 07:52 PM Reply With Quote
Same problem, fit a low energy, sorted
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
Surrey Dave
posted on 5/3/14 at 08:03 PM Reply With Quote
Yeah But!
I was talking about the heat from cooking not the cooker hood itself.
Perhaps the halogen looking ones are sturdier in construction?
Anyway I'll give the low energy bulbs a go , but they probably won't reach full brightness until I've finished cooking
Cheers Chaps
mcerd1
posted on 5/3/14 at 08:28 PM Reply With Quote
its still not that hot - if it was you would be getting cooked while you stirred your dinner
McLannahan
posted on 5/3/14 at 08:55 PM Reply With Quote
I fitted GU10 LED versions in our old hood. Lasted at least two years and were still working when we moved out! Just cheap ones of eBay, nothing fancy!
jossey
Get an led bulb I put a strip led light in mine after similar issues
David Johnson
Surrey Dave
posted on 5/3/14 at 09:10 PM Reply With Quote
Modern Man
This really is a topic involving modern men, cooker hood bulbs!!!
I'll be starting a poll next to see what the favourite oil is for stir fry!!!
I use Morrison's stir fry oil + a bit of toasted sesame seed oil & soy sauce.................................
loggyboy
posted on 5/3/14 at 09:21 PM Reply With Quote
I went for some cheap led ones ftom ebay, but the standard transformer didnt like them. I could replace the transformer, but I just put 1 standard bulb and 1 led in, which added enough load to make the leds work.
Mistral Motorsport
steve m
posted on 5/3/14 at 09:36 PM Reply With Quote
Modern Man
I will ask the WIFE
hang on...........
Scuzzle
posted on 5/3/14 at 09:43 PM Reply With Quote
Are you remembering to wipe your fingerprints off the bulb after you have fitted them, the oil left by your fingertips blows halogen bulbs prematurely so I usually grab a bit of kitchen roll and grasp the bulb through this when fitting.
Poundland bulbs are OK, I have 4x GU10 bulbs in my bathroom ceiling that have lasted years and was £1 for a pair when Homebase was nearer £6 a pair.
coyoteboy
posted on 5/3/14 at 11:03 PM Reply With Quote
No point wiping them, it still leaves the residue, you need to put them in using gloved or cloth covered fingers. That said, wouldn't expect a cooler hood to use bulbs that high tech temp as its sat in the greasiest place in the kitchen. I'd suggest a dodgy set of cheap bulbs, followed by dodgy connectors/connection, followed by excessive vibration from the fan. I've replaced one of the 2 bulbs in 5 years at our house and we have shocking voltage control locally (voltage varies from 210-255v several times daily.
posted on 6/3/14 at 04:10 PM Reply With Quote
You need to wipe halogen bulbs with some meths to clean them. Our cooker hood bulb went 10 years ago and you soon get used to not having one.
