Author: Subject: Radiator size and location
Siduna
posted on 17/3/14 at 08:14 PM Reply With Quote
Hi!
I'd like to get some feedback from you guys on radioator size and location. I'm building a mid engined car based on a Hayabusa engine. I do not have the radiator so I'll have to invest in one anyhow. I'm sort of ambvivalent on whether it's best to place it in the front of the car or closer to the engine. What's there to consider other than having to have space enough to fit a radiator? I think (depending on radiator dimensions) that there's place either in front or cloe to the engine. I will not use the original water pump as I'll have to drive the scavenge pump ("standard solution" .... dry sump).
Writing with a broken pencil is pointless
