Author: Subject: type 9 box onto a flow??
stu205
posted on 5/11/04 at 12:56 PM Reply With Quote
as the title sudjests rearly does a type 9 box fit onto a 1600 crossflow?????
barrie sharp
posted on 5/11/04 at 01:24 PM Reply With Quote
yes it does if you do a search you will find it someware in past notes
the cars looking good" a blind man would be pleased to see it"
''stop press'' the blind mans seen it said "it felt ok"
stu205
posted on 5/11/04 at 01:39 PM Reply With Quote
though it did but was just checking! cheers
stu
posted on 5/11/04 at 03:39 PM Reply With Quote
Two things to remember:
1. You'll have mix-n-match clutch components;
2. Bolts from g/box to engine block are UNC, and those from block to g/box are metric.
Apart from that, it's dead easy (it's what I've got).
rgds,
Deckman001
posted on 5/11/04 at 05:07 PM Reply With Quote
I've been told the clutch to use is from an early 1600 pinto, and if you are doing the same as me and using an alloy bellhousing you will need to re-drill the starter bolt holes in the sandwich plate.
Jason
posted on 5/11/04 at 06:17 PM Reply With Quote
Or use the sandwich plate to match the bell housing!! Hope this helps. Rusty.
Craig81
posted on 5/11/04 at 06:18 PM Reply With Quote
Very easy swap!!. just remember that it is a slightly longer box so the mount is further back. The splines in/for the clutch are of a different number to the 4 speed.
