franky
| posted on 17/4/14 at 01:23 PM |
Any building surveyors and/or damp and timber types on here?
If there is would someone be willing to give there thoughts on a part of a specialist survey I've had done on somewhere I'm trying to
buy.
I'll post it up here or PM.
Thanks.
james h
| posted on 17/4/14 at 04:16 PM |
I can't say for sure but mp3c on here might be able to help, or might know someone who can.
cb500t
| posted on 17/4/14 at 04:58 PM |
I'm a Building Surveyor for 37 yrs! first week was good !
MP3C
| posted on 17/4/14 at 05:04 PM |
Can send it to me if you like, will be able to have a look for you, however home buyer surveys aren't my specialty, however I am visiting my
parents this Easter and I am very good friends with a FRICS surveyor who is in the area and will defiantly be able to have a look if I can't
advise.
Matt
franky
| posted on 17/4/14 at 06:23 PM |
advise.
Matt
Hi
It wasn't a home buyers survey, done by a FRICS type person. I'm happy with his service, just that my mortgage company have put a 10k
retention on the mortgage till I have a damp and timber survey done. This is the D+T section of the report, basically I read it as about
£2.3k's worth of work needed? Anyone had a retention put on a mortgage before!?
I am pleased to report:-
Woodborer infestation
Roof
This originally thatched property has been re-roofed in modern times, probably in the 1980’s
The roof covering is concrete interlocking pantiles on modern breathable roofing underlay.
The structure of the main roof comprises newer rafters in tantalised softwood carried on the original kingpost roof truss structure. The reason that a
new higher structure was necessary is that the original thatch would have been considerable thicker than the new pantiles and it would have been
required to maintain the roof line.
The remaining original structure is very strong with large section king post trusses carrying large purlins. The plaster lath ceilings are carried on
ceiling joists which span from the trusses to the perimeter walls.
An examination of the new roof timbers suggests that this is tantalised timber and therefore not vulnerable to wood worm attack. I did not find any
flight holes in the limited inspection that I made. I therefore concluded that it is unlikely that this newer timber is at risk.
I did find flight holes in the older timber. I found the holes generally accepted to be the furniture beetle. I did not find the larger holes
associated with death watch or long horn.
The level of damage is of this order: Trusses and purlins Minimal
Ceiling joists more extensive and widespread. The ceiling joists looked to have been less seasoned than the more finished trusses and purlins.
My advice is that this roof void should be treated.
Prior to treatment the residue of thatched material should be removed.
This is a large roof space and I would estimate that the cost of remedial spraying would be of the order of £1,250.00.
Upper floors.
The house was generally carpeted and therefore a full examination of the top surface of the floor boarding was not possible, in the scope of this
survey neither was an examination of the floor void. Lifting carpet at the edges revealed a minimal outbreak of furniture beetle attack in a sporadic
set of outbreaks.
I concluded that the effect on the floors was minimal. My understanding is that you propose to carry out rewiring and installation of heating pipes in
the course of a refurbishment programme. My advice is given in the context of that information.
The infestation in the floors is minimal and would sensibly be dealt with in conjunction with your proposed works. The recommended procedure for
treatment of upper floors is to take up every fourth board and spray the underside of the floor boards so exposed and the sides of the exposed joists.
In practise a heavy spray into the floor cavity and soaking the top surface of the floor boards has the desired effect. Most treatment firms will
operate on an adhoc basis, coming in to spray to suit your programme. I would estimate that the cost of this should be no more than £750.00 for the
whole operation to the upper floors. This work could be done on a DIY basis as guarantees are generally more appropriate to the roof .
Staircase.
I noted that there was a moderate outbreak in the under stairs compartment and would recommend that this is cleared out and sprayed during the course
of the upper floor visit.
Damp Penetration
The construction of this house is generally a stone foundation (visible at the road end of the property) possibly bearing onto the underlying rock
surface. This was not an invasive survey so I cannot be sure of that statement but I detected very little movement in this house which is unusual in
basically a medieval structure.
The stone visible would largely be impervious.
I found only one area that had a hollow floor and floor boards on the ground floor that was the lounge. The whole of the house was carpeted at the
time of my inspection and therefore only a minimal inspection by lifting carpet was possible. Generally I found trowelled concrete. I suspect that
this is screed overlaying the original flagstones.
The wall structures are a combination of stone walling, brick and framed construction faced externally with render.
The house exhibited a high level of surface moisture on the walls and it suggests to me that much will be achieved by the introduction of heating and
ventilation.
In relevance to damp testing, the house is basically in two sections: the main largely original house built in a combination of stone, brick walls and
window surrounds with rendered exterior. Internal walls are stone and medieval studwork probably with brick infill. The second section is the rear
single storey extension, which is much more modern. This extension contains the kitchen and bathroom which are both fully tiled. Where it was possible
to take readings it was found to be dry and therefore ignored.
A standard protimeter test was taken at 1m centres around the ground floor walls. Readings were taken where possible and relevant. Readings are not
relevant in tiled, dry lined or panelled areas.
The circumstances in which the test was taken are relevant. In this case there is not heating in the house and the house has been closed up for in
excess of 12 months. There were no windows open on the day of my inspection
The main house
In a house of this construction, modern accepted forms of damp proofing would not be appropriate. For example, it would not be possible to introduce a
damp proof membrane into the walls because of their form of construction.
It is possible that a vertical membrane system such as Delta could be used in discrete areas such as the sitting room. In the dining room, stripping
off the rotten introduced timber boarding and exposing the base structure, combined with the recommended heating and ventilation would achieve
positive results. A view could then be taken as to if anything at all would be necessary after that.
zilspeed
| posted on 21/4/14 at 12:21 PM |
advise.
Matt
Hi
Roof
Upper floors.
set of outbreaks.
Staircase.
Damp Penetration
ventilation.
The main house
If I might, I'll make one or two comments being an MRICS qualified Building Surveyor and also having had the dubious honour of carried out
rotworks in my earlier years.
All of the following based on never having seen the property.
It appears that the costs for the recommended works are very modest indeed and whilst they were positively identified in the roof and mid floor voids,
the appraisal if the ground floor in respect of dampness is really not very conclusive at all. The suggestion is that removal of the affected timbers
to the ground floor 'should' be enough.
Given the costs I've seen for rotworks before, the suggested level of £2.3k is not very sore at all. I'd be less inclined to feel so
positive about the ground floor until I had seen the construction with the timbers removed. The report also fails to identify the exact nature of the
rot, without which it's not really possible to go any further.
I wouldn't like to comment further at this point.
MP3C
| posted on 21/4/14 at 05:22 PM |
Sorry it took so long to get back to you, its been a busy weekend. Without seeing the property it is hard to comment on the description he has given.
I am guessing that due to the fact that the person carrying out the works may not have been qualified in respected bodies - assuming this due to you
saying "It wasn't a home buyers survey, done by a FRICS type person" then I am sure the bank will be slightly wary of the details
given hence give you a slight retention on the mortgage. This is only an assumption and im probably not the best person to comment on this due to me
not having to deal with surveying work that is required for mortgages as I survey houses owned by the company I work for.
I would like to stress however that if you get a damp and timber survey done then I would highly recommend paying for one opposed to obtaining one
free from a company. Usually if they are free they find work that doesn't need doing where if you pay for one they are more impartial.
Hope everything works out for you and sorry for not being able to give a good answer
Matt
franky
| posted on 22/4/14 at 11:40 AM |
Walls are solid brick/stone, the house is covered in render, some of it concrete not lime.
The 'damp wall cladding' is screwed direct onto the inside walls so any damp that moves as the walls breathe goes directly into the wooden
covering. I'm led to think in this age of property the covering is only suppose to last till it rots
There's a few rotten floor boards on the first floor, looks like old woodworm has been at them.
The Specialist survey I've had put up was done by a FRICS person. Other places have said the cost for a whole house treatment of woodworm(if
its still alive!) would be about half the cost as its empty and they can have free reign.
