Author: Subject: Pulley help
Plunky
posted on 23/4/14 at 11:44 AM Reply With Quote
Pulley help
Trying to source a pulley to go with the Retro Ford alternator mounting kit.
Retro Ford sell the following pulley to match... bit expensive though
http://www.retro-ford.co.uk/shop/node/213
Does anyone know of a cheaper alternative that will work?
Liam
Dick Axtell
posted on 23/4/14 at 11:59 AM Reply With Quote
+1. Clearly a (future) problem area.
r1_pete
I made my own from a beetle alternator pulley, but, finding a pulley say a fiver, and another fiver post, then a couple of high speed bearings, probably another tenner with post, machining and fabricating time and cost, £37 isn't that bad.
Unless you can get something bolt on, I think I'd go with the retro ford item, if I were doing another zetec.
me!
posted on 23/4/14 at 12:21 PM Reply With Quote
I think I ended up getting one from a Transit Connect- but it was a home brew alternator mounting based on the Retro Ford one. I can't remember the exact model/part number, but a quick search on the GSF website should find you something suitable.
loggyboy
posted on 23/4/14 at 12:31 PM Reply With Quote
I used a Mercedes one:
MERCEDES SPRINTER /VITO/VIANO V RIBBED BELT TENSIONER PULLEY 6112000570
However you will need a bolt from the merc (or a similar) as it has a wide opening (12mm iirc) and the bolt has a thicker waist.
I got mine from a scrapyard when I went hunting for suitable pulleys, took the used pulely and bolt to trial it, and then replaced the pulley with a new one.
Mistral Motorsport
johnemms
posted on 23/4/14 at 01:08 PM Reply With Quote
MONDEO MK3 IDLER PULLEY FOR FAN DRIVE BELT 2.0 2.2 BRAND NEW
[Edited on 23/4/14 by johnemms]
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
loggyboy
posted on 23/4/14 at 02:13 PM Reply With Quote
IIRC thats the same spec and part number as the merc one.
Mistral Motorsport
Plunky
posted on 23/4/14 at 02:18 PM Reply With Quote
this looks almost identical to the one RF are supplying, can anyone confirm it is the same?
loggyboy
posted on 23/4/14 at 02:45 PM Reply With Quote
I doubt it matters. Providing it has enough ribs, (most do), it fits on the mount/bolt (diameter), and you have suitable bolt/washer arrangement, any pulley will do.
Mistral Motorsport
loggyboy
posted on 25/4/14 at 12:57 PM Reply With Quote
Just checked through my files and realised it is in fact this one I purchased - it has an m8 hole the bolt would be easy to get hold of without any spacer.
Mercedes Sprinter Vito V Belt idler Pulley 190 C E G S SL 6012000770 Diesel
Mistral Motorsport
LoMoss
posted on 28/4/14 at 08:03 AM Reply With Quote
Hi
Anybody used this?
And if so, can they post a picture of where/how its mounted before I go looking for one at the scrappies.
Tensioner part
Ta
Moss
[Edited on 28/4/14 by LoMoss]
