Author: Subject: Duratec 2.0 crank pulley.
Thatcher
posted on 1/5/14 at 08:03 PM Reply With Quote
Hi all.
Is it that hard to get the crank pulley bolt undone!!!!
I have locked the engine on a engine stand via the flywheel, took a 600mm breaker bar to the bolt and it wont budge.
Can I ask for any advince on undoing said bolt.
Thanks.
Tony.....
[Edited on 1/5/14 by Thatcher]
posted on 1/5/14 at 08:31 PM Reply With Quote
A decent impact wrench will undo it in seconds
mggareth
posted on 1/5/14 at 09:18 PM Reply With Quote
hi the torque is 100nm then 90 degrees so yes v tight
i use a 3ft bar
Gareth
