New Topic New Reply
Author: Subject: Polo Radiator fixing measurments
tims31
posted on 2/5/14 at 03:50 PM Reply With Quote
Having done some research into the radiator for my Fury I wonder if someone could do me a favour and measure their Polo radiator fixing points?
Reason is, I was told the Fury mounting points are to accept a mk2 Polo radiator (85-90. 1.1-1.3 number 171.121.253 CF or CJ) which has a core dimension of 430x 320 however I also know that the person who collected their chassis before me had his mounting points in the wrong location.
The measurements I have for the chassis are in the picture below, 460mm centres x 180 centres. I want to know if the Rad details I have will fit properly without me having to make up some brackets?
Rad-fixing
Rad-fixing
Build: http://www.martinsfurybuild.co.uk/
Smoking Frog
posted on 3/5/14 at 11:26 AM Reply With Quote
Maybe of no use (different size rad). Polo MK1 fixing centres are 414 x 180.
tims31
posted on 3/5/14 at 11:33 AM Reply With Quote
Thanks Smoking Frog,
The Mk1 will be no good then. I was hoping someone with a Mk2 rad would send in the dimensions, I know there are loads with them fitted.
Slimy38
posted on 3/5/14 at 01:27 PM Reply With Quote
Some Ebay auctions have the measurements on the pictures, for example;
VW POLO 1.7 1.9 SDI 96-99 MANUAL RADIATOR NEW
Although I think the width is measuring the wrong thing? I'll see if I can find another.
skov
posted on 3/5/14 at 03:37 PM Reply With Quote
I've got this one (1983-1990):
http://www.ebay.co.uk/itm/281080612617?ssPageName=S TRK:MEWNX:IT&_trksid=p3984.m1439.l2649
The mounting holes are approx 415x180mm apart.
tims31
posted on 3/5/14 at 06:35 PM Reply With Quote
Yes i've seen these but it doesnt really tell you the mounting point dimension but does give you a rough idea of the width
I've got this one (1983-1990): VOLKSWAGEN POLO 1983-1990/DERBY/SEAT TERRA/KIT CAR RADIATOR NEW-2 YEAR WARRANTY TRK:MEWNX:IT&_trksid=p3984.m1439.l2649 The mounting holes are approx 415x180mm apart.
I guess this is the one I have seen quoted for the 1ltr where as I think the one I need is for the 1.1 to 1.3 ltr and looks like it has a smaller core
Davey D
posted on 3/5/14 at 07:33 PM Reply With Quote
I've had 2x polo radiators. Same model, but different brand. The spacing of the pegs on the bottom were slightly didn't. Around 6mm overall. I ended up having to modify the bottom brackets to be able to fit the replacement radiator
tims31
posted on 3/5/14 at 08:19 PM Reply With Quote
I won't be using the bottom pegs, I will be using the holes on the sides to attach to the vertical uprights on my chassis which is why I am after the measurements.
omega 24 v6
posted on 4/5/14 at 07:38 AM Reply With Quote
Go onto www.northernradiators website. They used to have all the dimensiond on there. And they were cheap.
Samuele
posted on 3/6/16 at 10:24 AM Reply With Quote
s
New Topic New Reply
