Author: Subject: What tool for grinding out a weld in a corner...
jps
posted on 9/5/14 at 07:38 AM Reply With Quote
As per title really. Imagine you've got a box with no lid on it. What tool would you use to grind out a weld that went right into the inside corner of the box?
Obviously an angle grinder won't get in there - and a drill will just slip about all over the place.
Wasn't sure if I needed something like this: http://www.diy.com/nav/fix/power-tool-accessories/grinding-discs/grinding_stones/Bosch-Grinding-Stones-Set-2609256549-9286509?ecamp=SEAPLA9296209& ef_id=Uz539AAABaEkouA4:20140509073311:s
But am not sure how well they will fare against MIG weld on 3mm steel...?!
designer
posted on 9/5/14 at 07:44 AM Reply With Quote
A small grindstone will take forever to cut a weld in 3mm plate.
Depending on it's position, can you cut down it with a hacksaw?
Slimy38
posted on 9/5/14 at 07:51 AM Reply With Quote
I'm currently using a black and decker powerfile to tidy up some inside corner welds, problem is it's got a fixed radius on the end so it can't go past a certain point.
posted on 9/5/14 at 07:53 AM Reply With Quote
You'll be there for ever with a Dremel type tool and as you say it will wander about all over the place.
You could use a power file like this...
...but it still won't get right into the corner.
Question - why do you need to get the weld out of the internal corner? Most people just live with it there or design around it if necessary. e.g. cut a chamfer on mating parts to clear the weld bead.
...Beat me to it Slimy
[Edited on 9/5/14 by nick205]
NigeEss
posted on 9/5/14 at 07:54 AM Reply With Quote
A good quality carbide burr in something like a Dremmel. Don't waste your time with stones or HSS burrs.
If it's a MIG weld then bear in mind this will be a bit harder than the mild steel plate and choose a burr
accordingly.
(MIG wire is harder than mild steel so that it stays straight during the feed process)
[Edited on 9/5/14 by NigeEss]
jossey
posted on 9/5/14 at 09:04 AM Reply With Quote
Dremel
David Johnson
DW100
posted on 9/5/14 at 09:14 AM Reply With Quote
Die grinder with a carbide burr.
teegray19
posted on 9/5/14 at 10:21 AM Reply With Quote
A good quality big carbide but single cut
Built Formular 27 with 1600cc crossflow, 1700cc 0 miles crossflow, Kawasaki ZZR1100
jps
posted on 9/5/14 at 11:24 AM Reply With Quote
Thanks for the feedback - I have used a (cheap) Dremel type grinding stone in the past with little success (when trying to cut out for mounting of a master cylinder in the back plate of my pedal box) so did suspect 3mm mild - or MIG weld - would be too much for them...
I'm probably being over cautious about having nice clean welds in anticipation of IVA. It's a weld which holds a gusset to a plate which the roll bar stays will mount to. It's been welded (not by myself - but a professional welder) properly on one side - but I wanted to finish the job off by running a bead of weld down the other side. But I made a mess of it.... I had intended to clean it out and try again (once I'd perfected my welding technique) so it all looks neat and tidy...
I think i'll see how far I can get with a handfile before I invest in a powerfile....
FuryRebuild
posted on 9/5/14 at 11:39 AM Reply With Quote
+1 for the Carbide Burr in a die-grinder.
That's the right tool for the job, and will shift anything.
Can you get a flap-disk in there on an angle-grinder - that's surprising in what it will shift.
www.furyrebuild.co.uk
jps
posted on 9/5/14 at 12:33 PM Reply With Quote
Can't get in with an angle grider - had a Google of 'Carbide Burr'. Any reason I can't use one in the chuck of a decent drill?
MikeR
posted on 9/5/14 at 12:43 PM Reply With Quote
Drills aren't designed for sideways loading so you'll knacker it, eventually.
jps
posted on 9/5/14 at 12:46 PM Reply With Quote
Cheers - I hadn't considered that!
NigeEss
posted on 9/5/14 at 05:10 PM Reply With Quote
Also the drill is far, far too slow. Burrs are designed to run in the 10-20000 rpm range, use a dril
and you'll simply take chunks out of your expensive burr.
Eltel
posted on 9/5/14 at 05:21 PM Reply With Quote
Die grinder from machine mart
