Author: Subject: non lsd to lsd
andygfc
posted on 10/5/14 at 07:13 PM Reply With Quote
non lsd to lsd
I've been offered a 7" sierra 4x4 lsd
What else will I need to fit this in place of my non lsd?
Thanks in advance
fesycresy
posted on 10/5/14 at 07:52 PM Reply With Quote
Are you drum or disc at the moment?
You'll need drive shafts (complete) and depending on the number of splines on your tripods, you may need new hub carriers.
I'll post a picture when I get on a pc later.
snapper
posted on 10/5/14 at 08:00 PM Reply With Quote
If your going Lobro (bolt on) to Lobro ( bolt on) nothing straight swap
If its a push fit diff on the car and a bolt on LSD, it can be done by modifying the shafts but not easy to get the right bits
I eat to survive
I drink to forget
andygfc
posted on 10/5/14 at 08:11 PM Reply With Quote
Thanks guys
Trying to take it all in, mechanics aren't really my thing
I have discs on my car, but I don't know if bolt on or push in shafts. Only bought it last week, and not had chance to look it over properly yet
I've not driven the car yet, other than round the block, so not sure if lsd is really necessary. Car is for predominantly track use though.
Ben_Copeland
posted on 10/5/14 at 09:18 PM Reply With Quote
If your going on the track then you'll need an LSD, the last thing you want is one wheel spinning up coming out of a corner and sapping all your power
Ben
Locost Map on Google Maps
Enter Your Details Here
sjmatthews
posted on 11/5/14 at 08:18 AM Reply With Quote
Unless you have a lot of power, you may be ok with some sticky tyres and an open diff.
I'll be in the garage dear!
snapper
posted on 11/5/14 at 08:30 AM Reply With Quote
If you have discs on rear its most likely you have Lobro (bolt on) drive shafts and the diff will most likely be for bolt on shafts
2 Ford LSD's were common 3.62 & 3.9 for 7" diff and 3.64 for 7 ½" diff
The 3.9 was found on the 2L DOHC 4x4 the 3.6 on the V6
I eat to survive
I drink to forget
matt_gsxr
posted on 11/5/14 at 10:57 AM Reply With Quote
But, lots of folk run disc conversions to their drum set-ups, so I wouldn't be quite as confident of the above.
Post up a picture of both ends of a driveshaft, and the rear upright.
http://jpsc.org.uk/forum/
andygfc
posted on 11/5/14 at 01:40 PM Reply With Quote
Pretty sure they are bolt on. So if so a straight swap?
snapper
posted on 11/5/14 at 01:57 PM Reply With Quote
The balance of probability is if discs fitted more likely to be standard not conversion
Whilst I take the comment in to account the odds are in my favour
I eat to survive
I drink to forget
