dan8400
posted on 12/5/14 at 07:42 PM |
Suspension rocker/ bell crank question
Hi everyone
I am making some suspension rocker arms for a single seater. Do I need to mount them on bearings or can I use a bush of some sort?
Dan
[Edited on 12/5/14 by dan8400]
Hey - That's Journey!!!
bi22le
posted on 12/5/14 at 07:57 PM |
JPSC cars used to be on bushes and were changes to roller bearing to reduce wear and cope with the excessive forces going through them.
By excessive I mean more than required. Do a search and you will see that inboard suspension and rocker arm style trick stuff has its faults.
Please read my ring story:
dan8400
posted on 12/5/14 at 08:14 PM |
These are what I want
http://img832.imageshack.us/img832/350/ra15.jpg
I have this chassis. Bought it second hand (although it's NOS). Can't get hold of the company that made it for parts though. So I am
unsure how the rockers are bushed/bearinged up
Dan
adithorp
posted on 12/5/14 at 08:24 PM |
Most Fury's are on nylon bushed rocker arms. Problems have arisen where the pivot has seized/corroded; One of mine went tight after the first
year. Adding a grease nipple and regularly checks and service cure that. 6 years of use and I've had no further problems.
Some have been converted to needle roller bearings, though there are reports of them failing prematurely, as the range of motion in the rocker is
limited and the load is constantly on the same bearing.
http://jpsc.org.uk/forum/
dan8400
posted on 12/5/14 at 08:28 PM |
So by adding a grease nipple you can use nylon bushes no problem?
Which grease do you use? I have a grease gun
Dan
Sam_68
posted on 12/5/14 at 08:36 PM |
The image you picture is just a 'rocker' rather than a 'rocker arm' (the latter tends to imply a rocking wishbone, a la Sylva
or Lotus 25).
That arrangement tends to develop some axial thrust, which needle rollers on their own can't cope with.
You need to use either a taper roller bearing (which tends to be quite heavy/bulky), or a combined needle roller/needle thrust bearing (eg the
Nadella), which are expensive, hard to source (though you can get
separate needle roller and needle thrust bearings and use them in combination) and tend to develop 'flat spots' through excessively
loading just 2 or 3 of the needles, or else you use DU style shell bearings and thrust washers and replace them regularly as a 'service
item'.
Nylon bushes, as used on the rocking wishbones of some (most?) Sylvas and Fishers won't last two minute on a rocker (pushrod/pullrod) set-up.
You pays yer money, and you takes yer choice... as bi22le suggests, there's no perfect solution. ![](/images//smilies/sad.gif)
dan8400
posted on 12/5/14 at 08:38 PM |
I have seen the nadella bearings and, yes, they are very expensive
Did you look at picture I posted? Just wondered how they mounted that. Just looks as if it's bolted straight through the chassis
Not saying that would work just trying to fathom out how they've done it
Dan
dan8400
posted on 12/5/14 at 08:39 PM |
or Lotus 25).
item'.
Edited to amend title error
Dan
dan8400
posted on 12/5/14 at 08:49 PM |
I take it something like this is no good?
http://www.bearingboys.co.uk/OB101316_Plain_Oilite_Bearing_Bush-3654-p
Dan
adithorp
posted on 12/5/14 at 08:52 PM |
Dan
Sorry, wrote my reply based on the original title/info before you posted the bell-crank picture. No I wouldn't use nylon bushes for those.
dan8400
posted on 12/5/14 at 08:54 PM |
Ok no problem.
Dan
Sam_68
posted on 12/5/14 at 09:04 PM |
Yes, it may well be a DU bearing with DU thrust washers (in which case it may well be bolted straight through the chassis with a DU bush as a
'sleeve' and DU thrust washers either side... or with needle rollers/needle thrust bearings doing the same job), but people use all sorts
of solutions - some completely half-arsed - so I wouldn't like to guess!
Personally, I wouldn't touch a nylon or poly bush in that application - you need a good long axial distance along the rocker pivot (as
you have with the Sylva/Fisher rocking wishbone arrangement) to avoid excessive distortion of the bush with something as soft as plastic, but
that's not to say that someone might not have tried!
FWIIW, I tend to prefer the DU bearing as a solution myself; slightly higher friction than a needle roller, perhaps, but it's cheap, simple,
light and strong and doesn't 'flat-spot' like a needle roller can. I can accept arguments in favour of other solutions though - as I
said, there isn't a perfect solution that stands out above all others, I don't think.
dan8400
posted on 12/5/14 at 09:07 PM |
Thanks for that Sam
Dan
Sam_68
posted on 12/5/14 at 09:10 PM |
Dan
Yes, plain oilite bearings are another solution, though you'd need thrust washers/thrusts bearings to take the axial thrust with those, too, and
I don't think their friction/wear characteristics are quite as good as DU bearings.
dan8400
Good info Sam. Thanks
