gaz_gaz
posted on 17/5/14 at 07:40 AM |
AB Paddleshift kit
Morning chaps.
Are any of you using the AB Performance Paddleshift system.
How are you finding it and does it turn with the wheel?
Also, What are the alternatives to the AB setup.
I'm aware of the electronoc systems but I'm only thinking cable at the moment.
thanks
Gary
sdh2903
posted on 17/5/14 at 02:14 PM |
I had the AB kit on my last car, they are expensive but very very good quality.
As with any mechanical paddle it is fixed so doesn't rotate with the steering wheel, the paddles are quite large so you can still grab a gear
with the steering wheel turned.
I saw a couple of other kits around but seemed a little flimsy in comparison to the AB one plus the service from Andy is second to none.
van cleef
posted on 17/5/14 at 05:02 PM |
I've a kliktronic system on my car with push button system with a trick shifter incorporated with it. I hated it from day one as there was no
feel in the gear changes and finding neutral was a complete pain.
I now have the AB performance paddles with the cable setup and is so much easier to use and the kliktronic system is still on for the sake of the
trick shifter.
theprisioner
posted on 17/5/14 at 08:34 PM |
I have the AB system, it was easy to install and works very well. The support was excellent.
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
