Author: Subject: crimp tool for superseal/molex pins
blakep82
posted on 18/5/14 at 09:05 PM Reply With Quote
whats good?
i have no idea what to look for, and i see some at 60 quid. i don't have 60 quid for one, i want one 10-15, preferably less.
yeah you get what you pay for, but i'm buying one out of protest
people keep saying they'll do my wiring loom, then i never hear from them again and they don't answer my emails, so;
whats decent and cheap, since i'm going to have to get on and do this myself
best i've got is one of these, which i've never managed to have working properly, and i don't think its up to these type of plugs
i think i've got one of these somewhere too, do these work?
[Edited on 18/5/14 by blakep82]
________________________
loggyboy
posted on 18/5/14 at 09:25 PM Reply With Quote
The one your most likely to have is for coloured insulated terminals, (just a simple oval hole clamp) where as the one pictured is for non insulated, ie the superseal style 'legged' pins that double back on them selves, hence the M shaped crimp clamp.
I went for a cheap rachet version, circa £8 from ebay. However due to the delicate nature of them, I would suspect the non rachtet version youve pictured may be even easier to control.
The rachet ones crimp both cable and insulation legs at same time.
Heres the results from first try of mine:
http://www.locostbuilders.co.uk/viewthread.php?tid=181073
Mistral Motorsport
big-vee-twin
posted on 18/5/14 at 09:38 PM Reply With Quote
I usually fold them and squish them with long nose pliers then finish off with soldering, makes a good joint and makes use of the tools I have.
Never had one fall off.
http://www.triangleltd.com
blakep82
posted on 18/5/14 at 09:44 PM Reply With Quote
you're right! the end is different.
the one you got isn't listed by that same guy any more
i can't work out if this is the right type or not?
Electrical Ratchet Crimping Tool Pliers interlocking non insulated bullets AT672
or this one?
Non-insulated Crimp Tool - 3.9mm Bullets, 6.3mm Terminals Crimping Bullet un MP
i've done that before, often end up bending them or breaking them, and getting frustrated with them lol and i've got a LOT to do, so need efficiency in this case
daviep
posted on 19/5/14 at 07:10 AM Reply With Quote
Have a look HERE and pick which ever fits your budget. FYI I have a set of the cheapo pliers and find they work well enough, not sure where I got them from.
Regards
Davie
loggyboy
posted on 19/5/14 at 10:02 AM Reply With Quote
I'd go for these:
Non-Insulated Crimp Tool - 6.3mm, 3.9mm Bullets Flag Terminals Crimping Spade DL
or these are similar to mine:
Non-Insulated Tab Terminal Crimper Plier AWG28-18 SN-28
No idea how good they are though as they are slightly different.
Mistral Motorsport
blakep82
posted on 19/5/14 at 10:16 AM Reply With Quote
Cheers davie, I'd go with mp71, but after vat and post is added, its up to 15 quid, which isnt bad, but the same as these Non-insulated Crimp Tool - 3.9mm Bullets, 6.3mm Terminals Crimping Bullet un MP
Before I knew it, i'd gone with loggys suggestion, under a tenner, ratchet etc, clicked buy it now before I even knew what I was doing
Cheers lads
Edit, bah, should've checked the item location. Over a week for delivery from gibraltar. Email address is cliefromchina, ah well, no rush
[Edited on 19/5/14 by blakep82]
40inches
posted on 19/5/14 at 10:19 AM Reply With Quote
I have used one of these Ref MP71 from VWS for years, give a OEM finished crimp.
