Author: Subject: Sierra LSD Diff unit
gaz_gaz
posted on 19/5/14 at 07:54 PM Reply With Quote
Evening chaps,
I'm looking for a Sierra LSD ideally complete in a casing and a 3.62 ratio. and push in shafts to make things easy.
The closer to Maidenhead the better but it must be in good usable condition first and foremost.
cheers
Gary
matt_gsxr
posted on 19/5/14 at 09:25 PM Reply With Quote
Fairly sure that push in shafts don't work with LSD. LSD are all bolt on.
http://jpsc.org.uk/forum/
gaz_gaz
posted on 19/5/14 at 09:42 PM Reply With Quote
Oh ok.
well is it as simple as removing a diff and push in shafts and replacing with an LSD unit and bolt on shafts?
Wadders
posted on 19/5/14 at 09:44 PM Reply With Quote
You have u2u
snapper
posted on 20/5/14 at 04:40 AM Reply With Quote
The push in hubs are different, there is an article on converting specific push in shafts to a hybrid bolt on at the diff push in at the hub variant but requires diesel push in shafts of the same diameter as bolt on shafts
I eat to survive
I drink to forget
gaz_gaz
posted on 20/5/14 at 06:15 AM Reply With Quote
Ok.
is there anything stopping me from changing, diff, shafts and hubs in that case?
The diff in the car has been ran low on oil so I figure I might aswell swap in a LSD while I'm here.
mcerd1
posted on 20/5/14 at 07:10 AM Reply With Quote
its not really going to stop you but the 'bolt-on' shafts all used disc brakes on the rear, so your drums won't just be a strait swap - most folk seem to swap to rear discs too - but that could upset your brake balance.....
(I think you can fit the drums to the bolt-on hubs, but it may involve some tweaking as most of the dimensions are a little different)
gaz_gaz
posted on 20/5/14 at 07:21 AM Reply With Quote
My car already has discs on the rear but has an open diff with push in shafts.
hkp57
posted on 20/5/14 at 07:44 AM Reply With Quote
Get a standard open diff with push in shafts with the ratio you want then add a ATB diff unit from Quaife or 3J
ATB diffs are better suited to lighweight cars on combined road and track use and are a fit and forget item.
Fleet
SKC Raptor R - Hayabusa
Toyota C-HR Hybrid Limited Edition
Honda VFR1200 CrossTourer
DCT
Marlin Roadster 1800
Mercedes Vito 116 Sport
Wadders
posted on 20/5/14 at 07:45 AM Reply With Quote
I had some custom drive shafts made by GB engineering, in my case push in spline at the diff end and lobro spline at the hub end.
Lighter and stronger than the sierra ones as a bonus.
gaz_gaz
posted on 20/5/14 at 08:29 AM Reply With Quote
to be fair that does sound a better idea than changing diff. shafts. hubs. brakea and it's now been said I'd need to do uprights aswell as MNR use diff uprights for lobro.
hkp57
posted on 20/5/14 at 11:54 AM Reply With Quote
You can check the splines match on your shafts from this DRAWING
You can either buy the diff on its own like this Quaife
Or a complete unit ready to bolt in "Complete Unit"
Fleet
DCT
