Author: Subject: Lathe Work- Shaft Required
obr_technology
posted on 21/5/14 at 12:55 PM Reply With Quote
Hopefully somebody will be glad of some beer tokens in exchange for two shafts I need making.
I've got the technical drawing and can supply the material if anyone is able to help.
To give an idea the pair of shafts are identical, roughly 200mm long and 34mm dia.
PM me if you can help and I'll send over the drawing or Solidworks file.
Olly
[Edited on 22/5/14 by obr_technology]
tegwin
posted on 21/5/14 at 02:05 PM Reply With Quote
Is your big shaft going to require much polishing!?
Sorry...couldn't resist.
Might be able to help if no one else can but I am pretty busy for the next week or so.
www.verticalhorizonsmedia.tv
obr_technology
posted on 21/5/14 at 03:01 PM Reply With Quote
Damn Autocorrect!
Sorry, this was meant to say 'LATHE WORK'!
obr_technology
posted on 21/5/14 at 03:02 PM Reply With Quote
Haha, yes lots of polishing!
I should have also asked if anyone knows anywhere i can get heat treating done as i will need the shafts and a couple of gears heat treating.
DW100
posted on 21/5/14 at 03:39 PM Reply With Quote
Is it just lathe work or does it involve splines etc.?
obr_technology
posted on 21/5/14 at 04:55 PM Reply With Quote
I'll PM you.
DW100
posted on 22/5/14 at 09:12 AM Reply With Quote
Got your PM, I have a lathe but do not any facility to cut the keyways accurately.
obr_technology
posted on 22/5/14 at 10:42 AM Reply With Quote
Thanks, i've got a mill at work so will ask if one of the lads could do the keyway for me.
If you don't mind i'll send over the drawing to see if it would be possible?
HowardB
posted on 22/5/14 at 11:06 AM Reply With Quote
Tempered tools in Sheffield do heat treatment, - contact there is Mike Martin,...
Howard
obr_technology
posted on 22/5/14 at 11:42 AM Reply With Quote
Thanks Howard.
nero1701
posted on 23/5/14 at 09:23 AM Reply With Quote
I've lathes, mills and heat treatment at the college if you still need help, Located in Bromley
obr_technology
posted on 23/5/14 at 11:11 AM Reply With Quote
You have u2u
