Shaunk10
posted on 21/5/14 at 06:12 PM |
Need help with my propshaft
Hello,
I have had the UJ fail on my car which in turn has twisted the end of the prop shaft slightly and ruined the coupling that attaches to the dif and the
joint that's welded to the end of the shaft.
However the shortened propshaft has a brand new UJ at the gearbox end which is fine (much thicker and stronger too)
Now my plan is to cut the old joint and coupling off at the end that goes into the dif.
Then get a spigot machined into each section so they sit square into each other then simply weld a new end on and get it balanced.
Now my struggle is knowing what UJ and propshaft I should be looking for from a donor vehicle?
It's all from a 1983 sierra, am I right in saying that propshaft a from mk2 capris or escorts etc which look the same in pictures, may well be
the same?
As the coupling that bolts into the sierra dif may have different bolt patterns? Or are all fords generally the same bolt patterns?
Cheers again people!
DavidM
posted on 21/5/14 at 07:12 PM |
The general consensus with propshafts is to get one made. I've bought a couple. The last one was £115 delivered and took two days to come. Tell
them the gearbox, the diff and the length between the two and a brand new one turns up balanced and ready to go.
Proportion is Everything
ReMan
posted on 21/5/14 at 07:22 PM |
Agreed
By they time its balanced by a prop specialist and having had a failure, you want to get one made to your application
www.plusnine.co.uk
Shaunk10
posted on 21/5/14 at 08:21 PM |
May I ask who that was with for £115 mate, thank you both
DavidM
posted on 21/5/14 at 09:35 PM |
It was Autoprop:
http://www.autoprop-uk.co.uk/
I think others will be similarly priced.
HTH
Shaunk10
posted on 21/5/14 at 09:48 PM |
Cheers mate
johnemms
posted on 22/5/14 at 02:20 PM |
Propshaft Prices 2013 ish
I'm going with D&F - quick response - right price first time..
How much for a new propshaft ? See Attachment Jpg.
Super seven type car short propshaft.
Ford Sierra Type 9 box.
Ford Escort rear axle.
autoprop-uk.co.uk
hi cost of prop £120.00 pounds quick service plus vat and delivery
CF Parkinson Ltd
Cost to build this on standard universal joints £139 + vat and carriage.
commercial-propshafts.co.uk
We would quote £128.50 Plus Vat and carriage costs would be £7.00 plus vat.
propshaft.co.uk D&F propshafts
Price for your shaft will be £105.00 + 12.50 carriage + vat as applicable.
Bailey Morris Ltd
Price will be £129.00+vat - delivery charge will be £14.00 +vat via TNT.
Please note that payment by credit card will incur a charge of 2%.
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
Nurburg2006
posted on 22/5/14 at 09:04 PM |
There's one on eBay at the moment. Item number 231237075829 might be of use.
ste
posted on 23/5/14 at 04:28 AM |
Northwest propshafts £70 cash
