Author: Subject: Ford mondeo problem
steve8274
posted on 27/5/14 at 07:07 AM Reply With Quote
Ford mondeo problem
Hello all
I am in need of assistance and hope you can help.
I have a mondeo 1.8tdci 57 plate and just recently it has developed a noise.
When changing gears from 1st to 2nd and then into 3rd there is a loud clunking noise. That's the best way I can describe it. Doesn't do Everytime and the noise seems to come from the front drivers side but it is difficult to say if that's exact location.
Any suggestions what it maybe? Have looked in engine compartment and can't see anything obvious
Regards
snapper
posted on 27/5/14 at 07:44 AM Reply With Quote
Could be driveshaft UJ
Try turning wheel while driving slowly and go ON/Off with accelerator
If it clonks as you go on/off its a UJ
I eat to survive
I drink to forget
big_wasa
posted on 27/5/14 at 09:55 AM Reply With Quote
They are infamous for the dual mass fly wheel falling to bits.
Any strange noises from the starter motor ?
Nickp
posted on 27/5/14 at 10:06 AM Reply With Quote
+1 was just about to say this.
snapper
posted on 27/5/14 at 10:08 AM Reply With Quote
Easy way to check DMF is to take off starter motor if the starter is full of fine grey dust the DMF is on its way out
I eat to survive
I drink to forget
steve8274
posted on 27/5/14 at 12:24 PM Reply With Quote
Tried steering car and accelerating slowly and no noise. It's only when I go to change gear. It's as if it's doing it when you put load on and let off again.
The dmf was changed at 102k miles. Done 140k now so shouldn't really be that. Noise isn't the same either
snapper
posted on 27/5/14 at 01:48 PM Reply With Quote
Your into a minefield of hurt
I have a 2003 Mondeo TDCI and so far have replaced lower arm, springs as one broke, front hub bearing absolute pig to get out and needed a 10 tonne press to put it back, driveshaft, inner driveshaft centre bearing, both rear hub bearing packs
You should get the front up in the air, and check by hand for any play
I eat to survive
I drink to forget
theprisioner
posted on 27/5/14 at 02:45 PM Reply With Quote
+1 springs
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
posted on 27/5/14 at 04:09 PM Reply With Quote
Simple things first which are also the most likely: check the exhaust, "dog bone" engine tie-bar, front whisbone bushes and ball joints.
steve8274
posted on 27/5/14 at 07:24 PM Reply With Quote
Thanks all
Plenty for me to look at
Ninehigh
posted on 27/5/14 at 10:45 PM Reply With Quote
Why am I thinking of an engine mount?
steve8274
posted on 28/5/14 at 06:51 AM Reply With Quote
Last night I checked all suspension, springs and indeed engine and gearbox mounts. No obvious signs of wear and no movement on them when I try to lever them.
Stumped😟
Ninehigh
posted on 28/5/14 at 10:34 AM Reply With Quote
Is the gearbox on the drivers side?
steve8274
posted on 28/5/14 at 02:29 PM Reply With Quote
No passenger side.
Mot due next month so may put it in early and see if they spot anything
