Author: Subject: lawnmower type q
theconrodkid
posted on 30/5/14 at 02:19 PM Reply With Quote
lawnmower type q
i have a briggs 35,thats 3.5 horse power not the 350 hp twin turbo V8 model,after it has been running for about 15 mins,the engine starts to run a bit rough,like it,s flooding,puffs of black smoke from the exhaust etc,had the carb and air filter to bits,all looks ok.
any ideas peeps ?..
who cares who wins
pass the pork pies
posted on 30/5/14 at 03:16 PM Reply With Quote
yes, it's knackered.
spark plug?
posted on 30/5/14 at 03:21 PM Reply With Quote
How old is the petrol, fresh?
benchmark51
posted on 30/5/14 at 03:26 PM Reply With Quote
choke stuck on, running too rich, needs a rolling road and re-map?
GeoffT
posted on 30/5/14 at 03:27 PM Reply With Quote
Is it rich or oily smoke John? The B&S engines have a breather pipe that runs from the crankcase to the air intake which means if you tip them on their side when you clean underneath you get a carb/air filter soaked in oil. I usually tip towards the back of the mower, this seems to be ok.
Overfilling with oil can give similar issues, you need to check the level with the dipstick screwed in, not just resting on the top of the threads.
Usual problems with the carb are the diaphragm, or blockage in the pickup pipe that dips into the tank - these usually cause fuel starvation though, doesn't sound like your problem.
posted on 30/5/14 at 03:56 PM Reply With Quote
Sounds like an excuse for a BEM to me. ZX6 should see you round the garden pretty quick.
D Beddows
posted on 30/5/14 at 04:35 PM Reply With Quote
I had one that did this - then it started to not want to start, then it wouldn't start........ bought a new cheapo electric one and haven't looked back
To be fair I never looked after the Briggs engine (10 years old) but I messed about for ages with it when it broke and everything works as it should according to a manual I found but it still runs like a bag of sh*te - life is too short and grass doesn't stop growing at this time of year
theconrodkid
posted on 30/5/14 at 04:40 PM Reply With Quote
cheers guys,no choke so cant be that,new petrol,ill have a look at the breather pipe as i do turn it on it,s side to clean out,as for BEM.....dont put ideas into my head
garden is too big for a lecy one anyhow,i know i would run over the lead and chop it....just like i did with my hedge trimmer
[Edited on 30/5/14 by theconrodkid]
who cares who wins
pass the pork pies
D Beddows
posted on 30/5/14 at 04:47 PM Reply With Quote
Does it start to run normally when it's about to run out of petrol? mine did which (along with a compression test) told me it was the carb. Took that to bits and cleaned it (and the breather pipe) in a proper ultrasonic tank and........ no better. I wasn't buying a new carb 'just in case' so I left it to be honest
GeoffT
posted on 30/5/14 at 05:27 PM Reply With Quote
...bit careless John.....leaving the hedge trimmer on the lawn whilst you're mowing it
theconrodkid
posted on 30/5/14 at 07:05 PM Reply With Quote
never run it out of petrol,it,s fine for the first 15 mins or so then starts to play up and geoff....you know what i mean
who cares who wins
pass the pork pies
ste
posted on 30/5/14 at 07:07 PM Reply With Quote
breaks and scrap'em
[Edited on 30/5/14 by ste]
mark chandler
posted on 30/5/14 at 08:52 PM Reply With Quote
Mine did something similar, put a new carb on it for £15 off eBay sorted it.
It also stopped running if half empty on fuel and if it started struggling if I tilted for a couple of seconds it would sort itself out.
I could not see anything wrong with the old one, it may have just been a knackered gasket.
MikeR
posted on 30/5/14 at 09:32 PM Reply With Quote
Know nothing about the engines but if its always after 15 mins could it be heat related?
theconrodkid
posted on 31/5/14 at 07:45 AM Reply With Quote
Mike,thats what i am thinking, i start at one end and when i reach the same point every time it starts playing up.ill have the carb apart again but if it,s something too complicate it may be time for a new one
who cares who wins
pass the pork pies
posted on 31/5/14 at 08:49 PM Reply With Quote
Tried a new spark plug?
I wnder if pouring water or placing wet cloth on just thr carb being careful none gets inside to cool it down makr a difference
Does aound like hrat related,
Does it cut out when idling?
Does winding up the speed makr a difference?
theconrodkid
posted on 1/6/14 at 06:56 AM Reply With Quote
new plug on order,changed the oil,washed air filter and it runs better now,i think the problem may have been the govenor springs....pinkies crossed :-)
who cares who wins
pass the pork pies
